MadScientistMatt
MadScientistMatt UltimaDork
3/23/24 5:37 p.m.
wae said:
When I was basically almost all the way back home when it occurred to me that it seemed awfully weird that they need to order in a bolt.  I wonder if their plan is to replace the whole turbo.  Again.
Hopefully it's just some sort of weird and exotic bolt - nickle iron, wavey, or something else to make it stay torqued at high temperatures.
wae
wae UltimaDork
3/26/24 6:57 a.m.
I popped a new fuel filter on last night.  I think this might actually fix the fuel leak.  The back side of the filter looked more like this:
Indy - Guy
Indy - Guy UltimaDork
3/26/24 7:44 a.m.
Fingers crossed that fixes it
wae
wae UltimaDork
3/26/24 8:57 a.m.
Confirmed this morning: they're putting another new turbo on the thing.  Wyler wouldn't submit it for warranty coverage for one turbo and MB Cincy has now done it for two!
tester (Forum Supporter)
tester (Forum Supporter) HalfDork
3/27/24 9:17 a.m.
This thing stays broker than plate glass in a 70s action flick.
LOL
3/27/24 6:16 p.m.
They very much are very fancy high temperature rated fasteners and you have to remove the turbo for access to extract it... and it probably ain't coming out without a major fight, meaning damaged threads in the turbo.
Of course, they are inverted Torx, but this is a godsend if you have ever tried to insert a bolt on a socket on an extension way back where you can't see what you are doing.  They don't fall out of sockets the way normal hex bolts do.
wae
wae UltimaDork
4/1/24 9:31 a.m.
Picked it up this morning and things are running way more betterer.  The turbo sound is gone, it doesn't make my eyes water a little, and the low-end grunt is back.  I'm guessing that since it's running so much better, the broken bolt must have been in the collector such that exhaust pressure was bleeding off before the turbo.  If the exhaust was open post-turbo, it would make a literal hot mess under the hood and smell and sound bad, but I wouldn't think that would affect performance.
Lof8 - Andy
Lof8 - Andy UltraDork
4/1/24 9:32 a.m.
Quick, sell it!
(mostly kidding)
wae
wae UltimaDork
4/1/24 10:26 a.m.
In reply to Lof8 - Andy :
In all honesty, I'm kind of thinking that what I want is an Armada or QX80 for slightly greater towing capacity and a simple naturally-aspirated gas V8.
Indy - Guy
4/1/24 12:59 p.m.
In reply to wae :
Do it.  Quickly.  Before anything else breaks.
WonkoTheSane
WonkoTheSane UltraDork
4/1/24 1:11 p.m.
Yeah, at this point, I think we can confidently say that they were right.   It cannot, in fact, be fixed.
But that's all on their engineering ability, not on your mechanical :)
Sell it quick!
eastsideTim
eastsideTim UltimaDork
4/1/24 2:54 p.m.
Indy - Guy said:
In reply to wae :
Do it.  Quickly.  Before everything else breaks.
FTFY
FJ40Jim
FJ40Jim Reader
4/1/24 9:40 p.m.
No!
If Wae bails on this, who will I commiserate with?
Certainly not the huffy stuffy MB enthusiasts on their forums, who don't actually work on the vehicles. cheeky
BTW, I will now curse my vehicle by saying it's been.... like 6 months since the last MIL, which was bad ABS sensors. So tomorrow the tranny will fall out of it.
Recon1342
Recon1342 SuperDork
4/1/24 10:00 p.m.
In reply to FJ40Jim :
MB certainly seems to be trying for the smorgasbord of failure modes...
wae
wae UltimaDork
4/5/24 9:06 a.m.
We made it to Gainesville last night:
The MPG is a little optimistic, but calculating it myself, I came up with about 18mpg.  Not bad for 70mph pulling a trailer.
FJ40Jim
FJ40Jim Reader
4/16/24 7:44 p.m.
Drove the ML350 & towed the camper to PittRace last weekend for 24HL. On the way there, while pulling hard up a long grade, the CEL came on & stayed on. Vehicle continued to run fine, as usually happens. Scan tool came up with the usual "Undefined" code. Cleared the code at track. Drove home with no CEL.... OK, whatever. I'll keep driving this thing as long as it keeps running.
On the plus side, got 14MPG coming home because I didn't drive like a racer, got that outta my system at the track. wink
wae
wae UltimaDork
5/11/24 11:43 a.m.
I made the mistake of throwing away my extra empty Liquimoly oil jug and the oil extractor only holds 7 liters.  So today's oil change will be extra messy since I need to dump a couple liters in a drain pan before finishing the job.
But other than that, just a normal oil change.  Oil looks good and the filter is clean.  That one fuel line still seems to have a little leak in it, though.  Which is annoying.  I'll see about getting a new bit of hose and replacing it next week sometime.
FJ40Jim
FJ40Jim Reader
5/27/24 11:36 a.m.
Junkyard update: the PnP in Columbus shows a 2008 E320 Bluetec in the yard!  I was there for half price holiday weekend yesterday, but was disappointed to find the entire engine was gone, a long with exhaust DPF/cats, ECU, BCU, radio, etc.
On the plus side, they have an intact Volvo 244 Diesel, which coughed up a good intake manifold and PS pump& bracketry for my other turbodiesel project.
FJ40Jim
FJ40Jim Reader
6/3/24 11:20 a.m.
TPMS saved my wife's life yesterday.
She took off to go on 40-50 mile trip up the highway @ 60MPH. Made to the end of our little street and message center turned red & said "Check tire pressures!". Indicated pass rear was down to 10#, from 32.
Pulled up in front of the shop, verified tire was 11psi per my digital gauge. Started looking around, saw a nail in the middle of the tread. She sat in the car while I pulled out the nail, which was actually broken off of a longer rod, not a nail at all. It was an ideal candidate for string repair, so I did that. Let it cure for a couple minutes, reinflated tire, verified no bubbles, sent her on her way. I had her leave the TPMS up on display and she said it went from 31 to 34 while she drove, matching the other tires. I'm tickled that I fixed a $300 19" tire in less than 10 minutes for less than 1 US Dollhair.
Winning!
wae
wae UltimaDork
6/3/24 11:48 a.m.
That's winning for sure!  Having a TPMS system like that is actually pretty helpful.  What isn't helpful is the one in my wife's Mazda5 - That one just gives you a light on the cluster that there is at least one tire that is somewhere below not-low.  The rest is left as an exercise for the reader.
I don't leave home without my plug kit!
FJ40Jim
FJ40Jim Reader
6/3/24 8:18 p.m.
Hmm. My truck does not have a spare tire because the DEF tank fills some of the spare tire well. The factory spec run-flats have been replaced with conventional tires, because RFTs sucketh. A collapsible compact spare and the 12V compressor to inflate it was sourced from an R350 in the JY, so I'm covered in an emergency. But a plug kit would fit in the rear basement next to the compressor. I think you've talked me into talking myself into adding the stabby plug kit. Thanks!
wae
wae UltimaDork
7/29/24 7:28 a.m.
Not quite 3 months later and it's about time for another oil change.  The oil is on the way and should be here in time for me to get that done before heading to West Virginia this weekend for the next rallycross.  The last one was up at Joe's Speedway and getting there and back took basically one tank of fuel at 19.8mpg.  I wasn't in a hurry, so I was only doing about 68mph on the highway which got me about a 1.5mpg bump.  This past weekend, we took it down to McKee, KY to volunteer for the Boone Forest Rally and it worked out really well for that.  It was pretty neat to get it onto the gravel roads and drive it down a couple of the rally stages on our way to our work assignments.  For the second day, we even had a nice little spot to set up in at the flying finish.  We were going to park it a little differently so that we could put out the canopy, but as it happened the trees gave us all the shade we needed!
It's just under about 164k on the odometer right now and I've been starting to plan out what to do once the transmission goes out.  My first thought was to go ahead and get it sold/traded in now while it's still running and replace it.  Contenders so far have been the Lexus GX460, Infiniti QX80, Armada, an x166 GLS550, 4Runner, or...  something.  I did some preliminary shopping and came close to buying a GX460, but the problem that I've run in to is that the trade-in value is kind of low, apparently.  Since we don't have any immediate need to get rid of it, we started just making our "car payment" to a high-interest savings account and once we get to the point where replacing it moves into the "immediate need" category, we can use whatever loose change we'd get for whatever is left along with the cash saved up as the down payment instead of a trade-in.  If the truck lasts at least 4 more months, we'll come out ahead on that deal and on top of that it seems like used car pricing is trending down a little bit as well.
But that brings me to the current dilemma:  Tires.
I had new tires put on way back in 2017 at around 105k miles, give or take 5k miles.  They're not quite down to the wear bars yet, but we're starting to get close.  It seems kind of crazy to go and spend $1200-1400 on a set of tires - the math says that if I'm gambling on the transmission kicking the bucket before 200k, I'd be better off applying that $1,200 towards the replacement.  If I did that right now, then the car would only have to last 2 more months in order to be ahead of the trade-in value and these tires will more than likely get me through at least 60 more days.  I am gambling, though, so it's also possible that I could put tires on it now and get another 2 years out of it.  In which case, I'm way ahead.  Flip side, the driver's seat is getting pretty torn up and there is something rattling a little bit in the front suspension that should probably be looked at.  And it wouldn't suck to replace or fix the fender I banged up.  So that's a little more money to throw at it which would be totally worth it if it's going to last another couple years.  I'm leaning towards seeing if I can find a decent set of used tires that I could have put on to maybe find a bit of a compromise solution.  The problem, really, is that I really like driving it, I just don't know if I can trust it!
FJ40Jim
FJ40Jim Reader
9/13/24 8:34 p.m.
Quick update on our ML350. It continues to run surprisingly well, and is a very solid handling & braking tow vehicle.
Just finished a B (B+?) service. Changed engine oil & filter, air filters, fuel filter, cabin filters. Also did the recommended 'Extract all DEF & refill with fresh'. 5gals did not quite bring it to full, need to get another 2.5gal cube next time at NAPA.
The tire that I pulled a nail out & shoved in a string still had a slow leak (4-5 psi/week). The wheels were off to rotate, so the tire was dismounted and a 2" patch was clamped inside on the string repair. Seems to be holding 100% now. The tire repair was free, if I ignore the cost of tire machine.
The one mechanical problem is oil leaks at the front of both cam covers and at the steel sump.
It's messy, but only requires a 1 liter top off at 5k miles. A closer look showed that 90-95% of the joint is sealed. I elected not to attempt repair on the assumption that I would just end up with a leak elsewhere.
A look at the bug filled filters. Yes, the ram-air is quite functional.
And a pic from today, at Cowan Lake SP. Tow truck doing tow truck things.
wae
wae UltimaDork
9/15/24 10:14 p.m.
Well, things were going swimmingly until the parish festival.  There is something about the festival that just does bad car things to me.  One year it was emergency tires due to a puncture.  One year my whole family nearly got killed coming back from the festival late at night due to someone coming over a crest at a high rate of speed.  In our lane.  Where there was almost no shoulder.  And then, of course, we can't forget the year that the engine decided that the #2 rod bearing would make a tasty treat.  This year, on the way in to the festival this morning, the left front air strut went ka-bang.  It's an Arnott unit that I put on back in February of 2018, so it "should" still be covered by the lifetime warranty since they didn't go to the 24 month warranty until 2023.
But...  Rockauto says that the part is out of stock and they can't process a warranty return so they'll just refund the original purchase.  Which means I'd have to buy a new one.  That is more expensive.  And only has a 24 month warranty.  I think they just changed the flipping part number so they didn't have to deal with the lifetime warranties anymore.
Aaron_King
Aaron_King UltimaDork
9/16/24 1:18 p.m.
In reply to wae :
Have you contacted Arnott?  They may honor the warranty.
9lHtnCGR3f4GNlk3C9rbRj3wWRjshPBJdB1XzqdD7sEUMEozsJf88p7HJNN0E7Yo
