4 5 6 7 8
Crackers
Crackers Dork
1/6/18 4:20 p.m.
I guess to really get the scale of overkill you should see both sides.
759NRNG
759NRNG Dork
1/6/18 5:22 p.m.
Not quite sure what I'm looking at...........head held sideways squinting my eyes......
Crackers
Crackers Dork
1/6/18 5:27 p.m.
In reply to 759NRNG :
Probably need to go back a page. Sounds like you missed a post.
Rufledt
Rufledt UberDork
1/6/18 5:41 p.m.
i'm not sure anyone doubted your commitment to overkill, but that sure is nice to see anyway laugh
759NRNG
759NRNG Dork
1/6/18 5:41 p.m.
To cap off the ends where da mice used ta be livin' ? I give........
Crackers
Crackers Dork
1/6/18 5:47 p.m.
I was going to drill out the spot welds so I could save the inner sill to facilitate reinstalling the door plates but the top side is held in with about a million spot welds.
There's about 13 feet of that altogether, and unlike the rest of the car they're all still intact.
Knowing I was about to destroy the inner sill with the air hammer I made the profile tool above so I can make sure to get it right when I fabricate a new one.
Then, after pulling the inner sill I found more speed holes!
I'm probably going to have to remove those panels too. If so I'll try to reuse the dimples.
759NRNG
759NRNG Dork
1/6/18 6:05 p.m.
Thank you kind sir for the BIG picture. wink
Crackers
Crackers Dork
1/6/18 6:29 p.m.
In this installment:
Uncle Ben gets Jacked!
Ok, it's not really that special, but it is pretty cool if you ask me.
I didn't really take any pictures of this process as I was really on a roll. But here's the end product.
This very much a down and dirty job. Nothing was deburred, and I didn't even bother wire brushing most of it.
But you turn the 3/4" all-thread and it goes up. Turn it far enough and you can stick a pin in it and remove the lower stop.
With the pin in place the lower block can go up or down allowing me to lift/lower/ the whole length of the leg.
It's not terribly smooth through it's range of motion since hot dip galvanized steel has a pretty uneven texture, but it works, and I can literally shove the car around and it doesn't fall over. So that's nice.
Indy-Barely Functional-Guy
Indy-Barely Functional-Guy SuperDork
1/6/18 11:29 p.m.
nice work.
Belt and suspenders kind of fabrication.  well done.
Crackers
Crackers Dork
1/7/18 11:28 a.m.
In reply to Indy-Barely Functional-Guy :
Thanks! That was what I was going for.
NOHOME UltimaDork
1/8/18 10:07 a.m.
Welding that hot dip galvanized really sucks. Also don’t trust the penetration if it is something that could bite you; the zinc seems to defeat penetration for some reason.
Crackers
Crackers Dork
1/8/18 11:26 a.m.
Yeah, the coating has to be removed. I grind it back at least half an inch and it welds like normal.
Crackers
Crackers Dork
1/9/18 11:35 a.m.
Hi, my name's Crackers, and I'm a grindaholic.
Does a person need 8 angle grinders?
Well, not really, I'm kind of a special case.
However, these went on sale again at TSC and I wanted another one for dedicated wire wheel purposes.
As a bonus, the display model was the only one they had, and it was missing the grinding wheel and nut. The manager was anxious to get rid of it and I happen to have no need of the missing stuff, so I got an additional $20 off the sale price. (I also happen to have several spare nuts. laugh)
You'd have to be dumb to walk away from a brand new DeWalt for $29!
CLynn85
CLynn85 HalfDork
1/9/18 7:32 p.m.
Great progress, you're taking a very methodical approach! I'm completely dumbfounded by the door sill profile template, I'm lucky if I'm meticulous enough to cut a piece of cardboard, much less cut, roll, and stamp a piece of steel!
759NRNG
759NRNG Dork
1/9/18 8:18 p.m.
Welcome Crackers .....when was the last time you grinded?????
Rufledt
Rufledt UberDork
1/9/18 10:57 p.m.
I wish I had 8 grinders... I only have 1, and another ex-grinder.  For some reason it puked it's guts out.  Grinding is a hard life...
Crackers
Crackers Dork
1/10/18 9:28 a.m.
In reply to CLynn85 :
Thank you.
Being this deep into a car can be demoralizing. Days of work go by, nothing is finished, and there's still months of work ahead.
Sometimes doing something you can actually finish like making an over-the-top profile tool makes the light at the end of the tunnel a little brighter.
I'm officially at a point where I've done all I can without at least mocking up the chassis, so most of my time now is being wasted twiddling my thumbs while debating hypotheticals.
Crackers
Crackers Dork
1/10/18 9:55 a.m.
It's been about 18 hours, and I've got the shakes. surprise
In reply to Rufledt :
I'm pretty sure by now I've spent more money on tools for this car than I'll spend on actual parts.
When it comes to grinders, I've basically become a DeWalt fanboy.
Home Depot sells a $40 Ryobi rat tail grinder with a rotating handle that I used to really like for light sanding. (The rotating handle was key for ergonomics in my actual "work use".) A couple years ago they upped amperage/power and they get too hot and like to let the smoke out. Then again, I'm sure even before the change they weren't intended to run almost continuously for 3 hours at a time.
I've killed 2 of them since September, (and I'm not planning on replacing them) or it'd be 10. Of course, I may try to replace them anyway since I'm afraid of change.
Crackers
Crackers Dork
1/10/18 10:11 a.m.
I guess my point is, the key to longevity with most power tools is to stop and let them cool off when they get hot.
If you're doing a job that you need to really lean on a grinder (ie wire wheeling) or extended run time, it's going to get hot.
The $60 DeWalts like the one I just got will take a lot of punishment. The 13 amp USA made one will run all day pretty much regardless of what I do with it, even when it's 100° out.
If I'm really going to lean on something, I use my 7" Ridgid. (Like when I grind off the spot welds on the door sills.) Then again, it's heavy enough, you don't have to lean on it. LOL I bought it before I drank the Kool-Aid, but it's held up well despite seeing nothing but abuse.
759NRNG
759NRNG Dork
1/10/18 10:57 a.m.
Don't forget the the service center in Jersey Village off 290.......resurrected my Dewalt from there (switch/brushes)....good as new
NOHOME UltimaDork
1/11/18 7:22 a.m.
Thank you.
You are right on both counts. It IS hard to keep the faith AND it is very important to start and complete SOME task.
My brother and I were comparing the Molvo build to his through hike of the Appalachian trail. Remarkably similar highs and lows.
Crackers
Crackers Dork
1/12/18 6:29 p.m.
I was *[this close]* to dragging the chassis home today when I realized half my straps are missing and the ones I could find were all damaged/frayed.
So I ordered a new set of straps, and will be sitting on my hands until they get here.
I also picked up some rectangular tubing yesterday to reinforce the sills. So theoretically, I have all I need to make this thing roll again.
Crackers
Crackers Dork
1/13/18 3:47 p.m.
I finally got accurate measurements of the Lexus floor pan to compare to the gaping hole in the AMC.
Unbelievably, they're within 1/8".
As in the Lexus pan will pretty much weld right into the the Rambler sills.
USPS needs to get moving!
Patrick
Patrick MegaDork
1/13/18 4:44 p.m.
1/8” is clamp it together and weld it territory
Crackers
Crackers Dork
1/13/18 7:32 p.m.
That's what I'm saying!
I realized I have a plasma cutter and decided to try using it to cut out spot welds.
It actually works well, but the sheet metal is so thin that if I miss the smallest bit of intact spot weld and pull on the panel, the sheet metal tears or  creases.
And I missed a lot. So now I have a ton of panel repair to do.
Knowing what a mess I made on the passenger side, I made another profile tool for the lower sill before I start cutting the driver's side so I can at least get it back in shape. Although, I'm going to grind off the flange on the other side to avoid causing any more damage.
4 5 6 7 8
JX8zhcMSmGPdgvm5eSp1LPTy9cOaAeZV4MYVUVJCaMkW11fHW9tnK75gtMMkCskC
