ckessel
ckessel New Reader
8/25/24 11:47 a.m.
Hello there, my name is Carl. My longterm project is a 1965 Dodge Coronet 500 that I intend to use for driving events and autocross events along with daily fun driving. Maybe an occasional dragstrip run. This car is the cover car for the second edition of a Mopar Handling tech book from the late 80's. It belonged to a freind of mine who was good freinds with the two gents who owned the tech publishing company. Since I've mostly posted on another forum about the car, I'm going to put the link up to that site so those interested can read multiple pages over 8 years of my work. This will make it easier for me, writing wise. As I continue working on it, I'll add content directly here.
https://www.forbbodiesonly.com/moparforum/threads/updating-the-super-street-mopar.116131/
Manual_Trans
Manual_Trans New Reader
8/25/24 4:03 p.m.
That's quite an epic build! It's a beautiful car and it will be pretty amazing when you finally get it on the road again.
ckessel
ckessel New Reader
8/26/24 7:09 p.m.
Today was fairly simple. Cut/filed a couple of pieces to go between the front triangle piece and the side frame units. Once I had those fitted up, got out the Lincoln glue gun and welded them together on all 4 corners. Tomorrow will be grind the welds down and start laying out the lid. I still need to get the short straight filler neck and 60* fill hose from Tanks Inc. so I can cut the hole in the rear panel of the nest. I want to get that done before I secure it to the trunk floor.
ckessel
ckessel New Reader
8/27/24 6:09 p.m.
Today I ground the welds down on the frame. After that, I tacked it to the nest to help me get a handle on forming the lid up. Since I don't own a slip roller, I looked around to see what I had available to hand form the lid. Had a piece of 3" EMT so I used that. Its getting there enough for me to figure out what needs to happen on the rear portion which needs some compound forming.
MadScientistMatt
MadScientistMatt UltimaDork
8/28/24 12:49 p.m.
Nice to see a car with a history keep on going!
ckessel
ckessel New Reader
8/28/24 2:08 p.m.
Thank you.smiley
ckessel
ckessel New Reader
8/31/24 6:27 p.m.
Over the last few days I was working out what I needed to do on the rear portion on the lid where its arched east-west. I went through my textbooks from the class I took in 13 and found my solution. My thoughts were correct in that I needed to stretch that area on my wheel. Today I ran the lift up so I could get the wheel out from its spot along the wall and proceeded to work the needed area. It fits up way better after getting wheeled. My lack of continual working with the machine shows in some areas but the general outcome is fine. I was thinking about doing some bead rolls in it but decided that may cause other issues so its going to stay as is, smooth. Since it has the contours in it, its fairly strong so I'll make sure that nothing heavy can get on it making dents etc.
rustomatic
rustomatic HalfDork
9/1/24 5:41 p.m.
What an awesome build--the history element is amazing.  The Gear Vendors thing definitely retains relevance in the drag & drive world these days.  Looking forward to more!
ckessel
ckessel New Reader
9/1/24 7:26 p.m.
Thank you for that.
chandler
chandler MegaDork
9/2/24 8:19 a.m.
Very cool!
9/2/24 1:37 p.m.
In reply to ckessel :
I heart the old MoPars, and a 65 Coronet is one of the finest IMO. Looking forward to your posts!
ckessel
ckessel New Reader
9/3/24 12:11 a.m.
Thank you. Of the early b-body units, 62-65, I actually like the 64's best. I got such a deal on this car, plus I knew its original owner/builder, couldn't pass it up. This car replaced the 70 Challenger that I lost in a wildfire back in 07.
Ranger50
Ranger50 MegaDork
9/3/24 6:47 a.m.
What isn't said is the GV don't last long. They last but it's pretty much done after 1.5-2 events, sometimes even less, with anything having 4 digit hp.
I look forward to further updates because well old school muscle.
ckessel
ckessel New Reader
9/3/24 12:42 p.m.
I don't plan on using the GV when I'm throwing the car around. The trans was done by Pro Trans, a Torqueflite specialty company. They put together an essentially Class 8 or Trophy truck[ desert stuff] unit for me since they knew how it was going to get used. Similar deal on the converter by Continental.
ckessel
ckessel New Reader
9/4/24 6:57 p.m.
I set the tank nest into the frame and tried to set the lid into it. Didn't want to fit. Hmmm. Then I remembered that I added the floor mount flanges onto the nest making it a touch wider. So did some more grinding on the lh rail to remove more of the floor mount flange, pretty much flushed it up so its straight vertical. After that I welded the cut edge of the floor to the vertical edge of the rail to solidify them. Grind those welds down, then try the nest and lid again. Bingo.
ckessel
ckessel New Reader
9/5/24 7:00 p.m.
Since I failed to clean off a prior felt pen line, I managed to punch 12 extra holes in the wrong area near the front edge of the lid. So today I plugged up the holes. Some years ago I discovered that the removed piece, using my Blair Rotabroach cutters, can be used for plugging up holes. I measured the cutters until I found one that was 5/16" on the inside of the cutter. This piece ends up with a nice thin flange on the outside which gives you something to tack weld with. Got them tacked on the backside with the TIG then on the topside I used the TIG again with some Silicon Bronze filler to fill up the remainder of the hole.
ckessel
ckessel New Reader
9/14/24 12:16 a.m.
Made some more progress over the last few days on the 65. The back piece is trimmed up, ready for welding. I put some screws in the nest to hold it on the floor, this will get welded when I'm ready to do so, then cleaned off the next area ahead of it for the front piece. Made some measurements and cut out some material for the front piece. Wiped it down with Acetone, roughed it up for paint adhesion using a Scotchbrite disc, cleaned it off again with Acetone then doused it with Ospho. Today I marked out the front and back pieces for some bead rolls. This will take the flop out of the sheetmetal and give some rigidity back to those two areas.
ckessel
ckessel New Reader
9/14/24 7:56 p.m.
Today I ran the two next pieces though the bead roller after doing some pre stretching of the target areas on the english wheel.
ckessel
ckessel New Reader
9/18/24 1:08 p.m.
I back burnered the 65 for a bit. I have a 67 Coronet wagon as my daily driver. I'm taking it on the Hot Rod Power Tour West next month so its getting an oil change, checkover and cooling system update. The PO had put aluminum pullies on the crank and water pump which looks cool but the pump, fan, alternator and p/s pump are underdriven by 22%. Thats effecting my temps so I scored a pump and crank pulley from a gal who deals with old rides. I took the car to Famosa two weekends ago which gave me a good indication how it did in high ambient temps with the larger 26" radiator. Previously had a generic Nova/Mustang sized aluminum unit that didn't cool unless you were at speed. Plus he bent the fan blades to fit the trimmed down shroud. Useless! I'll get the car wrapped up today and see how it does with proper drive ratios.
wawazat
wawazat SuperDork
9/18/24 1:42 p.m.
The wagon looks great!
Good luck with the cooling system issues.  I struggled with those a few years back on my Cougar and went all gonzo on it to get it fixed-DeWitts aluminum BB radiator, dual electric fans (beefy motors) and shroud, FlowKooler water pump, correct Cleveland t-stat and diverter, blah blah blah.  It works wonderfully now and cooling isn't an issue.
ckessel
ckessel New Reader
9/18/24 2:01 p.m.
Just the new brass/copper unit made a nice difference, along with a fan thats not dorked up. Electrics may be an upgrade in the future but not now. The 65 will have them as that was part of the package from BeCool.
ckessel
ckessel New Reader
9/25/24 7:17 p.m.
Getting a little further along on the 65. The front fill piece is good to go on fit. I went ahead and pulled the nest back out as I needed to get an idea where my hole for the fuel line/vent line/wiring needed to be after I set the tank into it. Once that was marked, I marked for an additional 4 holes. 2 each for the front and back. These holes will be to enable some airflow to get through and out of the tank area for any potential seeping out of the sender and pump flanges. I do need to put a hole in the center of the rear wall but I'm waiting on that till my filler neck and filler hose show up. When I get those, I'll put the tank back into the nest, mark where the hole needs to be for the fill hose to pass through, then cut the hole. On the holes already cut, I used my 1.5" dimple die on them.
ckessel
ckessel New Reader
9/29/24 8:09 p.m.
The fuel filler neck and hose showed up this week. I put the tank into the nest to see where the hole needed to be
for the hose in the back wall. Got that marked out then got ready to cut the hole. The hose is 2.5" diameter outside
and I wanted a little bigger on the hole so I could make up a grommet to protect the hose from rub through. I didn't
have a 3" holesaw in my arsenal, I do have a 2.5" cutter but it needs to be replaced, I did have a 2" one so thats what
I used. Instead of blowing $25 on another holesaw, I marked a 3" circle on the metal with my compass. To get the
remainder out, I used my airsaw. Hole is made now. I went over the hole nest with some Acetone, then hit it with a
clean and strip disc, then Acetone again. I'll get the majority of it coated with some POR15 this week before it gets
welded in.
ckessel
ckessel New Reader
10/20/24 1:02 p.m.
Nothing to report on the 65 yet. I and a freind attended the Hot Rod Power Tour West earlier this month. I drove my wagon, 1967 Dodge Coronet/440/at/no a/c for the route. Burned lots of fuel and had a great time. Since I was gone for a week on that, I've been getting caught up on homeowner stuff so this coming week I should get some time in on the 65. Here are some pics from the tour.
Ap3dnOgcPX3lrpmyqsC1IZqRCFrQuDlhTkac63pl2A4AVKLSH9APImivQVYrZKqM
