svxsti
svxsti Reader
3/16/19 4:46 a.m.
In reply to hvoxi :
I did notice that, but apparently the 3.5 in the Altima  already has the HR heads, it just needs to be tuned as such.
sleepyhead
sleepyhead Mod Squad
3/16/19 5:12 a.m.
irish44j said:
svxsti said:
Boat anchor? They're the same dimensions as the fronts on a CGT with no engine or axle lol see these are the guys I wanna prove wrong. And if FWD is better on slippery surfaces, then it should be even better on dry. Just don't spin with the wheel turned lol
boat anchor = heavy.
20" wheels are heavier than 17" wheels, in the wrong place (outside diameter = more rotational mass). This is simple physics. If you can go fast with 20x9s that weigh 30lbs, you can go faster with 17x9s that weigh 20lbs. This is pretty basic stuff.
I really can't help but feeling this is a trolling post, at this point, so I'm out....
I don’t think you’re wrong, and this is the second thread pulling the same vibe in the last ~two weeks.
hatchback
hatchback New Reader
3/16/19 8:17 a.m.
svxsti said:
John Welsh said:
But...the G35\G37 coupe exists and has rwd
So doesn't the 350Z lol but they're heavier and don't have transaxles that can exit corners quicker.
C'mon, backwards Porsches anyone?
I know I shouldn’t feed the troll, but...
Except a “backwards Porsche” would be a FWD car with rear wheel steering. Not an overpowered Altima coupe with 20” wheels on rubber band tires.
Crackers
Crackers Dork
3/16/19 9:01 a.m.
I, for one, can't wait to see your theories in action. Surely you have something figured out that generations of performance engineers have overlooked for all this time.
Do you have a YouTube channel yet?
ProDarwin
ProDarwin UltimaDork
3/16/19 12:54 p.m.
I'd be amazed if an Altima with a HR swap and 20x9/255 combo could be competitive in even the slowest Autocross class.
svxsti
svxsti Reader
3/17/19 10:05 a.m.
In reply to hatchback :
Rubber band tires? They're the same sidewall as a 235/35 used by some of the fastest cars. Let's just make things up as we go along lol.
svxsti
svxsti Reader
3/17/19 10:06 a.m.
In reply to Crackers :
Of course, it's called Top Fear.
svxsti
svxsti Reader
3/17/19 10:15 a.m.
In reply to ProDarwin :
Have you not seen the the GTi Clubsport S does a 7:49.21 on the Nurburgring with rubber band tires and over 3000 lbs. Coincidentally it also makes 306hp. So yeah, I'd expect an AC that lost 150 lbs and set up the same would be just as fast, which is faster than a 996 GT3 at 7:54. Hell, I may even start club racing with these cars, 7500 rpm shifts and no intercoolers needed. Glorious.
ZmkpLu8tbt7AqxyMcVnVWhU8WPN09wYEfWbnSJs36Wm2NDpXwhV308IFhEERtnEA
