Alfaromeoguy
Alfaromeoguy Reader
2/22/19 2:17 p.m.
I will soon weld my new engine braces into my Alfa Romeo spider  bodyshell. Question. I can weld top and sides, easy. But the underside well be a wee bit of a problem. Can I just weld just top and sides, or need to do all sides. Engine dressed weighs about 325 pounds.
Alfaromeoguy
Alfaromeoguy Reader
2/22/19 2:20 p.m.
I think I will just weld all 4 sides
Brotus7
Brotus7 HalfDork
2/22/19 2:50 p.m.
Sounds like you made a decision. I'd weld as much as you can.  I'd the underside gets difficult to lay a bead, you can do a series of tacks next to each other.
What engine is it getting? Any competition use planned?
NOHOME UltimaDork
2/22/19 2:55 p.m.
Bevel the topsides so that you have a full depth weld, that will make the bottom weld almost redundant... and then do the bottom just cause it is not as hard as you think.  Practice makes better. Perfect I cant yet vouch for.
Clean clean clean is the one thing that I have learned over and over again. If there is soot in the weld zone, it is not clean enough. Acetone is my go-to for when it matters.
Pete
Alfaromeoguy
Alfaromeoguy Reader
2/22/19 3:26 p.m.
Brotus7 , 2.2 ecotec engine. No racing, just driving a Italian car like it should be driving, with passion.    No home, thanks on the  bevel tip, and  clean, yes very clean
vxRNY0y5GDdDIOd3iPbS0rczuzEUV2sURPKZvyq09jhCrE7oB7slh9xCwNCXnFSw
