1 2 3 4 5
EvanR
EvanR HalfDork
10/9/13 12:12 a.m.
singleslammer wrote: Sweet. I am looking forward to seeing the final product.
Hmm... A lot depends on your perspective. By tomorrow, Phase I will be complete. That is, it will be a weatherproof box, sleep-able, and ready for a maiden voyage. As time goes on, improvements and amenities (such as ventilation and lighting) will be added.
But just like a car project, is it ever really finished??
donalson
donalson PowerDork
10/9/13 12:41 a.m.
looking good... i've been enjoying seeing your progress, I love the idea of a small trailer for camping
Hasbro
Hasbro Dork
10/9/13 5:28 a.m.
It's really coming along. I've wanted to do this for a long time with a HF trailer.
4cylndrfury
4cylndrfury MegaDork
10/9/13 7:24 a.m.
Interested in seeing the interior take shape. Do you plan to insulate it at all? The pink/blue polystyrene sheets, or maybe the foil backed styrofoam stuff - both available at your local big box store, would probably do a decent job. Covered with some simple luan paneling, I think it would be a pretty decent place to sleep (both from a sound and a comfort perspective).
EvanR
EvanR HalfDork
10/9/13 11:37 a.m.
4cylndrfury wrote: Interested in seeing the interior take shape. Do you plan to insulate it at all? The pink/blue polystyrene sheets, or maybe the foil backed styrofoam stuff - both available at your local big box store, would probably do a decent job. Covered with some simple luan paneling, I think it would be a pretty decent place to sleep (both from a sound and a comfort perspective).
Design considerations were taken into account for the future of possible insulation. The 2x2 framing will allow 1.5" foam board to be installed fairly simply, should I choose to do so. I tend not to camp when it is too cold out, but that may change.
4cylndrfury
10/9/13 11:49 a.m.
EvanR wrote: I tend not to camp when it is too cold out
Probably because you never had a well insulated camping trailer
A dedicated inverter, a trickle charger, a spare car battery, and a small space heater, and youd probably be able to get away with am hour or 3 of heat in there...enough to keep the chill out with a good sleeping bag
donalson
donalson PowerDork
10/9/13 12:16 p.m.
Probably because you never had a well insulated camping trailer A dedicated inverter, a trickle charger, a spare car battery, and a small space heater, and youd probably be able to get away with am hour or 3 of heat in there...enough to keep the chill out with a good sleeping bag
how much heat did those older camp lanterns put off?... a quick look though and they are much more expensive then they used to be... but I bet it would take the edge off... or an indoor propane heater or something.
but I was thinking a battery going to a vent fan would prob be beneficial for warmer weather
EvanR
EvanR HalfDork
10/13/13 6:17 p.m.
Still too windy to do the final roofing, so I occupied myself with door hardware today. Some camper shell bits, some random junk from my collection of random junk, and some heat shrink tubing for pretty, and it comes out like this:
IMG_0166
EvanR
EvanR HalfDork
10/14/13 8:32 p.m.
Phase I is complete! Wahoo!
The roof skin is on! Coroplast! Yep - it's cheap, light, waterproof, and UV-resistant. What more could you want in a trailer roof? Held in place with shingle roof drip edge. Also light and cheap - easy to work with, too!
IMG_0168
Bit of a detail shot here on how all the trim goes on and holds everything in place and covers my sloppy seams.
IMG_0169
Don't have a metal bending brake? Couple of pieces of angle iron and a couple of clamps makes a passable brake, at least for .040 aluminum.
IMG_0167
And voila! We have nose protector!
IMG_0170
Now we have a sleep-able, sealed (enough) box for sleeping. It's been a longer haul than I anticipated, so I think I'll give it a rest before tackling ventilation and electrical.
donalson
donalson PowerDork
10/14/13 8:36 p.m.
did you use some sort of silicon under the drip edge to prevent water leaks and stuff?
still like it :) not as purdy as a tear drop... but it certainly looks like something I could build myself and be usable
Junkyard_Dog
Junkyard_Dog Dork
10/14/13 8:57 p.m.
I advise sealing EVERY exposed screw before the water finds its way inside. An ounce of prevention and all that.
EvanR
EvanR HalfDork
10/14/13 9:28 p.m.
oh yeah, there's a whole caulk gun tube worth of silicone under that trim.
EvanR
EvanR HalfDork
11/18/13 8:28 p.m.
Hey, remember this thread? I needed a little break, so I took one. Got back at it in the past week, so here's the update.
Part I: Electrical
Bunch of junk from the junk bin at work, and I have a complete electrical system :)
2@ 6V, 12Ah batteries from emergency lights, wired in series for 12VDC, mounted in a tray I fabbed up from a chunk of diamond-plate aluminum:
IMG_0175
A switch box I threw together. All switches have pilot lights:
IMG_0176
Here's the actual lighting. the green circle contains a LittleLite reading light, converted to LED. The blue circle is a strip of 15 SMD LED for general area lighting (it's WAY bright!), and the red circle is a piece of 1/2" square tube with 2 ordinary red LED, for night lighting/night vision.
IMG_0177
EvanR
EvanR HalfDork
11/18/13 8:33 p.m.
Part II: Additional exterior work:
Cut, caulked, and installed a bit of aluminum angle to seal the lower front joint:
IMG_0178
Then I solved a problem with the Coroplast roofing. On hot days, it was expanding and ballooning up, a good 3" from the subroof! I tamed that with some 1/8" x 1" aluminum flat bar:
IMG_0181
The outer two ends are done, the center will have to wait until the roof vent goes in.
ebonyandivory
ebonyandivory Dork
11/19/13 10:32 a.m.
As for heat, you can heat up a terracotta pot to red-hot in a campfire then bring it inside on a cooling rack or cast iron pan etc. and it radiates heat for quite a while.
admc58
admc58 Reader
11/19/13 11:03 a.m.
Nice work!
I would suggest putting some indoor/outdoor carpeting on the front lower edge to prevent rocks from bouncing off and chipping the paint on the rear of the Xb. Had that problem on a home built trailier years ago and did that to correct. Took me a while to figure out what was chipping my rear bumper and trunk...
4cylndrfury
11/19/13 11:07 a.m.
Looks great!
EvanR
EvanR HalfDork
11/19/13 12:45 p.m.
admc58 wrote: Nice work! I would suggest putting some indoor/outdoor carpeting on the front lower edge to prevent rocks from bouncing off and chipping the paint on the rear of the Xb. Had that problem on a home built trailier years ago and did that to correct. Took me a while to figure out what was chipping my rear bumper and trunk...
Interesting tip! Thanks!
donalson
donalson PowerDork
11/19/13 12:46 p.m.
ebonyandivory wrote: As for heat, you can heat up a terracotta pot to red-hot in a campfire then bring it inside on a cooling rack or cast iron pan etc. and it radiates heat for quite a while.
or something like this perhaps... although open flame inside a small wood structure is questionable
http://youtu.be/brHqBcZqNzE
EvanR
EvanR HalfDork
11/22/13 12:01 a.m.
I just need to gloat. It rained hard today, first time since I finished off the roof. And it's bone dry inside!
Brett_Murphy
Brett_Murphy UltraDork
11/22/13 10:10 a.m.
That isn't gloating, that is valuable, data-driven, performance related feedback!
EvanR
EvanR HalfDork
12/15/13 6:50 p.m.
Woo! Remember me? Now all the idiots on the road can actually see my trailer! In the pics below, heavy circles are LED lights, medium circles are reflectors, and fine circles are 3M Conspicuity Tape. If they don't see me now, it's their fault, not mine!
IMG_0208
IMG_0207
Timeormoney
Timeormoney Reader
12/16/13 7:37 a.m.
Very nice
EvanR
EvanR HalfDork
12/16/13 7:50 p.m.
Timeormoney wrote: Very nice
Thanks!
CLynn85
CLynn85 HalfDork
12/16/13 8:07 p.m.
Good work, keeping a running tab on the budget?
Slept in it yet?
1 2 3 4 5
75gjLQJxmMuKQmhympTJQnHAQY9dLHcc7TQvHOEOfkCfBeec4c4273u18lUJ9EfU
