1 2 3 4 5
93EXCivic
93EXCivic SuperDork
1/21/12 4:58 p.m.
Got the hood open by cutting thru the hood. The hood release itself was stuck shut. The weird thing is it wasn't stuck when I went and looked at it.
93EXCivic
93EXCivic SuperDork
1/22/12 4:51 p.m.
So I was trying to use this to remove the glue left over from the headliner but it isn't working worth crap. Any one have any suggestions?
SyntheticBlinkerFluid
SyntheticBlinkerFluid Dork
1/22/12 8:57 p.m.
a mixture of automotive paint thinner and wax & grease remover.
We used to use it all the time to remove the adhesive from the lettering on box trucks when I worked at the collision repair shop.
93EXCivic
93EXCivic SuperDork
1/23/12 8:20 a.m.
SyntheticBlinkerFluid wrote: a mixture of automotive paint thinner and wax & grease remover. We used to use it all the time to remove the adhesive from the lettering on box trucks when I worked at the collision repair shop.
Did you just mix it 50/50 and apply or apply them separately but at around the same time?
Graefin10
Graefin10 Dork
1/23/12 9:13 a.m.
3M Adhesive remover from NAPA
4cylndrfury
4cylndrfury SuperDork
1/23/12 9:18 a.m.
best goo remover Ive found is good ol zippo fluid (mostly kerosene I think).
kurtz
kurtz New Reader
1/23/12 10:12 a.m.
4cylndrfury wrote: best goo remover Ive found is good ol zippo fluid (mostly kerosene I think).
+1 Its naphtha.
1/23/12 10:30 a.m.
I use a 50/50 mix, Sometimes 60/40 and apply it with a rag, then usually scrape it with a putty knife/gasket scraper. Sometimes apply it twice then scrape.
Good idea to buy a gallon of each.
93EXCivic
93EXCivic SuperDork
1/23/12 5:11 p.m.
4cylndrfury
1/24/12 1:28 a.m.
Oooohh fancy!
93EXCivic
93EXCivic SuperDork
1/30/12 4:01 p.m.
Curmudgeon
Curmudgeon SuperDork
1/30/12 5:37 p.m.
Did you get 4 of those Minilites, you lucky dog?
93EXCivic
93EXCivic SuperDork
1/30/12 5:50 p.m.
Curmudgeon wrote: Did you get 4 of those Minilites, you lucky dog?
Yes thanks to GVX19.
JThw8
JThw8 SuperDork
1/30/12 6:04 p.m.
93EXCivic wrote:
You keep collecting this Yugo stuff and I'll have to break out the rare collectibles to tempt you. How about a dealership Yugo parts and service sign? Its lit and functional ;)
93EXCivic
93EXCivic SuperDork
1/30/12 6:09 p.m.
JThw8 wrote:
Pictures? I am trying to find stuff to put in my garage.
93EXCivic
93EXCivic SuperDork
2/14/12 7:56 p.m.
Look at that massive engine!
Mostly gutted interior.
93EXCivic
93EXCivic SuperDork
2/15/12 5:30 p.m.
http://grassrootsmotorsports.com/forum/grm/what-paint-scheme/45601/page1/
So I am leaning towards an Alitalia paint scheme.
http://grassrootsmotorsports.com/forum/grm/kyb-spring-rates/45620/page1/
And trying to figure out the strut options. May involve an A1 VW front struts.
2/15/12 9:35 p.m.
How did the glue removal go?
93EXCivic
93EXCivic SuperDork
2/15/12 10:04 p.m.
SyntheticBlinkerFluid wrote: How did the glue removal go?
Haven't completely yet. I am going to try so other things tomorrow after I clean up the floor pans.
93EXCivic
93EXCivic SuperDork
2/16/12 8:34 p.m.
Ok so there is a small hole near the seam in sill. The metal around it seems fairly solid. Should I just Bondo that small hole and put POR-15 over it or weld it up?
93EXCivic
93EXCivic SuperDork
2/29/12 8:24 p.m.
Graefin10 wrote: 3M Adhesive remover from NAPA
That stuff is the E36 M3.
93EXCivic
93EXCivic SuperDork
2/29/12 8:24 p.m.
I have been doing body work and removing things like the heater.
93EXCivic
93EXCivic UltimaDork
3/15/12 8:08 p.m.
The roof rack is deleted and the holes filled in. The side trim is removed and I have removed a decent amount of rust from the passengers side.
Does anyone know of a cheap source for fender mirrors?
Do you think it would look bad to have the interior of the car painted black and the outside a different color?
93EXCivic
3/15/12 8:10 p.m.
So the hatch is kinda E36 M3ty. I am pretty sure that I can't really repair it correctly. If I coat it with POR-15, will I be able to get this decently smooth with some work?
93EXCivic
3/16/12 12:16 p.m.
Anyone?
1 2 3 4 5
biOvedFlV4F15KUladOKvZmrCWqbzVXc1gWBnfsldpqyxWbZcmpHI6ndLhfKkAhP
