Carl Heideman
Carl Heideman
1/29/22 9:03 a.m.
1. Pick the Right Compound
Racing compounds go on a race car, while street compounds go on a street car.
2. Look for Leaks
If anything is leaking in your braking system, fix it immediately. Make a visual inspection of all brake components and look for wet areas–you should find none.
BimmerMaven
BimmerMaven New Reader
10/24/22 8:39 a.m.
7. Hoses
I've seen too many "looks OK" rubber bits that...aren't.  5-10 years for brake hoses, and they go.   Sooner for racing; steel braided for racing.
10.  Brake torque
Excellent point....if they can do it repeatedly at speed.   If not, better cooling.  Read the HP book.
frenchyd
frenchyd MegaDork
11/6/22 2:53 p.m.
In reply to Carl Heideman :
Always, always, arc the shoes to fit the drums.
mcloud
mcloud New Reader
10/3/23 12:12 p.m.
Did I not read in GRM or CM to not use the pedal-push flush method, but rather the Motive Products Power Bleeder?
10/3/23 1:07 p.m.
We usually bleed the traditional, two-person way: pump, pump, pump, hold.
Bky7EZLKRSIxBzFz5E8566FbDZHqTdnhu2PoXbiGRxHy3WbPVgviF54WUsNX9Lrw
