problemaddict
problemaddict Reader
6/8/09 4:06 a.m.
Hey gang,
I just got my mgb road worthy again after about a year of sitting. As stated the car has 68,000 miles on it. After a few jaunts around town the clutch pedal has started to take it sweet time returning to the up position. It has pressure on the down stroke, but slowly returns.
I'm assuming a problem w/ the clutch master or slave or both. With only 68K on the car, do you think the available rebuild kits would be appropriate, or should i replace one, the other, or both (at significantly higher expense!)?
Thanks for any experience/advice,
Mike
Tim Baxter
Tim Baxter Online Editor
6/8/09 7:53 a.m.
I usually try to rebuild 'em. Rebuild kits are cheap, and MG cylinders usually aren't.
Doesn't always work though.
Carl Heideman
Carl Heideman
6/8/09 9:29 a.m.
At Eclectic Motorworks, we usually rebuild both units at the same time. If one's failing, the other will fail soon--although the slaves fail more than the master cyls. Don't hone the master cyl--it's anodized and will get porous if you hone it. Just clean it really well and put the new rubber in. If it's scored badly, replace.
People complain that bleeding is difficult sometimes--it isn't if you take your time. We wait about 30 seconds between "bleeds" and it usually takes about 5-8 times to get the air out of the system. Don't pump the pedal when you bleed, just one down stroke at a time per bleed.
--Carl
problemaddict
6/8/09 4:46 p.m.
Thanks guys! That's a releif. I wasn't excited about spending the money on the replacements. I'll try the rebuild kits.
Shinsen774
Shinsen774 Reader
6/8/09 7:45 p.m.
Check the position of the bleeder on the slave.....they often ship it in one hole, when they should be installed in the other.
OFracing
OFracing New Reader
6/9/09 12:27 p.m.
I seem to get about a 50% yield rate on rebuilds. I usually try a rebuild first unless there's a obvious problem, like corrosion.
Just remember, some of the OEM rebuild kits have rubber parts that are 30+ years old too. Check them out before you use them.
mike
Jensenman
Jensenman SuperDork
6/9/09 4:40 p.m.
Check carefully for corrosion. Use a penlight or similar to get a really good look inside the bores. Water has a nasty habit of collecting at the bottom of the bores and leaving rust pits which render the casting pretty much unuseable. Pitting = replacement.
problemaddict
6/15/09 4:20 p.m.
Well, i got the Clutch M/C out and it looks a good bit corroded on the bottom Bummer. Which leads me to a search of M/C's for sale.
RockAuto has "Rhino Pac" master cylinders for a whopping $31!! Anyone use this brand before? Google gives me many places selling them, all between $30-=50. But Google doesn't give me any links to ppl who have used one. Encouragingly there's no horror stories posted either...
So, what's the deal? are they made out of balsa wood or something?
-Mike
problemaddict
7/4/09 12:43 p.m.
Hey,
Well, the Rhino Pac stuff showed up. Guess what? The master cyl is stamped "LOCKHEED MADE IN ENGLAND" just like the original.
Photobucket
Anyway, i guess Rhino bought up a bunch of NOS stuff? I dunno. I installed both the master and slave cyls yesterday and the clutch is workin' fine now. And during the job, i found a ton of rust in my floor! yay!
GSCReno
GSCReno New Reader
7/4/09 11:18 p.m.
More likely that the Chinese have bought Lockheed... Glad that you've got it sorted... That's one more classic car on the road. Cheers, Scott
mHr72FexjXuSOimOLgG9brpg6WPKz19qjh33215WlRzphYyIXZXTswAvuQVgfnUj
