karek
karek New Reader
1/2/15 1:28 p.m.
Bought a 1972 Karmann Ghia coupe, it has set in a garage for 10+ years and then in a barn for another 10+ years. Decided to get it running. Began by removing the fuel tank & fuel sender. The tank is intact but there was about 3/4 inch of tar in the bottom after I dumped the liquid out. I put a quart of aircraft paint remover in the tank and left in overnight. The next day the tar wasn't solid but very sticky. Poured out what I could and used a 1500 watt hear gun on the outside of the tank for about an hour. If you do this make sure you are in a well ventilated place because the fumes are terrible. Then I put 2 more quarts of the aircraft paint remover in. This time I got to bare metal. Took it to a car wash and you wouldn't believe the trash that came out of the tank. I have ordered a new fuel sender and have replaced the copper sleeve at the fuel tank supply/exit. The fuel line was partially plugged with tar and I used break cleaner. I would fill it and then use air pressure to blow it out. It took 3 cans before it came out clean. Will post as I proceed.
68TR250
68TR250 New Reader
1/2/15 6:53 p.m.
I had the tar /varnish cocktail in my 250 after sitting for 6 years. I tried cleaning it with brake cleaner, laquer thinner, and Simple Green. I kept getting crap into the carbs to the point that it actually shut the car down.
I gave up and spent the $70 or so to have a rad shop clean it out and seal it up. I still had to flush the fuel line back and forth several times with the laquer thinner until it finally cleared up.
Good luck with your cleaning process.
AngryCorvair
AngryCorvair UltimaDork
1/3/15 3:01 p.m.
i couldn't find a radiator shop who would do my fuel tank, so I taped up all the openings except the filler, then dumped a gallon of acetone in it. shook it around, poured it out, strained it, poured it back in, etc. got everything out with just one gallon of acetone.
Tom_Spangler
Tom_Spangler SuperDork
1/3/15 4:12 p.m.
This thread is relevant to my interests. I just pulled Ugly's tank yesterday and there's a ton of crud inside it.
karek
karek New Reader
1/11/15 1:05 p.m.
I have ordered and received a new fuel level sender and an electric fuel pump. Will begin re-assembly as soon as it gets a little warmer. My barn is not heated.
Trans_Maro
Trans_Maro UberDork
1/11/15 1:28 p.m.
Currently doing this to a 1982 Diana fuel tank.
Repeated swish with gunwash (pretty much lacquer thinner but way cheaper) with an occasional steam cleaning in between with a rented industrial steam cleaner.
It's been a week but I think I've got it all.
Shawn
eVVAemvQpUt5TQGHjJMSsLjUgXLll3MZjheoPUNREbrQclaAp2eAmpI9wELAxQJr
