The good news is our 60-year-old Corvette soldiered through this horrible weather just fine. The bad news is the left headlight door didn’t want to retract afterward, while the wiper switch became intermittent. As the car was not equipped with intermittent wipers, this was a real pr…
Another great solution (did you see what I did there?) is DeoxIt D5S-6 cleaner. A can should be included with the sale of any classic car! Spray it into any connector or switch, operate it a few times, spray again. It does exactly what the name says.
I also use a piloted spot-weld cutter (looks like a 3/8" hole saw) to clean around ground screw holes. Run it slowly and rock it a little bit and it will leave bright metal all around. Put a dab of grease on it, a star lock washer between the surface and the lug and it's good to go.
In reply to OldKartRacer :
I do see what you did there. :)
I have a can of CRC QD Electronic Cleaner in the garage. Useful for cleaning guitar equipment, too.
