Tim Suddard
Tim Suddard Publisher Emeritus
4/9/24 2:39 p.m.
Since we were running a supercharger and would be getting well north of 100 horsepower from our little, old 1275cc Sprite engine, we thought an oil cooler would be a wise investment.
Moss Motors sells a cooler and an installation kit for a Sprite for less than $200.
The kit c…
wspohn
wspohn UltraDork
4/9/24 3:41 p.m.
I've seen them mounted flat (i.e. aimed at the ground) with a small scoop under the car that sends air up through the cooler - it then exits either through or around the radiator depending   The only caution on that method is that if you ever make an off track excursion, the scoop may direct rocks at the cooler......might want to include  layer of 1/4" spaced hole hardware cloth/screen as a rock catcher.
9FZ4ur3TeBt15JijZqoErYo25O0NIjQD4P1i6EboV1sTMlX1Hz0I8yNBc0BMkWmw
