sprite_driver28
sprite_driver28 New Reader
1/24/11 5:25 p.m.
I am converting my '59 Bugeye to disc brakes and can't unscrew the fulcrum pins on the old (drum) a-arms (yes, I pulled the wedge pins). On the disc a-arms the fulcrum pins unscrewed no problem. What am I missing?
tvrvixen
tvrvixen
1/24/11 6:21 p.m.
Heat. And if all else fails cut the swivel off with a cutting torch.
sprite_driver28
1/24/11 8:42 p.m.
Crap! I was hoping that I was missing a hidden roll pin or something.
Thanks tvrvixen!
NOHOME Reader
1/24/11 10:58 p.m.
New a-arms.
Those buggers rarely come out without a fight. You can try a bunch of heat, but keep in mind that the threaded inserts are brazed into the a-arm and might come out. The threads are most likely buggered anyway,
sprite_driver28
1/25/11 8:57 a.m.
It's been wierd as the pins make about a quarter turn with no problems then stop tight. I suppose it's just the wonderful world of 40+ year old cars!
rbTYFDRR30Xu64NWjXr7Yjos2SWFaUlDxmUod0AbOIRyIMDfiO3ANZpZYGmZ1cGO
