Daryl
Daryl New Reader
9/9/08 1:32 a.m.
Ok, so I swapped a '92 240SX 5 spd transmission into my '66 Datsun roadster with the help of an '84 Diesel P/U transmission front half. It all works great, but I have a few questions about it all....
The "hub" or "collar" as it may be called will fit any of the Roadster, 240Z, 240SX, or Diesel p/u throwout bearings......
Would it matter which bearing I used? Would the 240SX bearing, being a newer design have any advantages?
The bearings have slightly different diameters at the point where they contact the fingers of the pressure plate (the roadster being the smallest, 240SX the largest)...Will that affect the pressure required to depress the clutch to a large degree?
Her's hoping someone might have some experience/insight....
Daryl
Jensenman
Jensenman SuperDork
9/9/08 7:48 a.m.
I'm assuming it's a diaphragm spring pressure plate. If so, the difference in diameter might have a small effect on pedal effort, but more important is that if the fingers are not flat making sure that the bearing contacts the raised part of the finger.
Curved finger pressure plate
Flat finger pressure plate
CGkxO7qAoJE3hqCfZvTYfxNx3vWKBJX5CRvJvhXtaptuKyRQM7mTT0ry3DhmlqmU
