Kenny_McCormic
Kenny_McCormic PowerDork
7/21/14 12:09 a.m.
Just a good well tuned 4 barrel and free flowing exhaust will probably wake it up quite a bit.
The_Jed
The_Jed UltraDork
7/21/14 1:53 a.m.
Kenny_McCormic wrote: Just a good well tuned 4 barrel and free flowing exhaust will probably wake it up quite a bit.
And a set of heads from a '96-'01 Exploder, they should bump up the compression a bit too.
Kenny_McCormic
7/21/14 2:10 a.m.
In reply to The_Jed:
I suppose it is only a couple dozen more bolts at that point....
Of course at that point you start running into problems, like the old trans starts slipping.
The_Jed
The_Jed UltraDork
7/21/14 5:28 a.m.
In reply to Kenny_McCormic:
It's a slippery slope!
belteshazzar
belteshazzar UberDork
7/21/14 8:03 a.m.
Rad_Capz wrote: The 460 does not fit well in a 68. It CAN be done but the changes made in 69 were to accommodate the 429/460 engine family. Check the torque boxes for rot as they're often not even connected anymore due to rust and the cowls rot around the fresh air ducts under the dash. If it takes on water in the rain check the cowl.
I didnt realize a 69 was different than a 68.
Rad_Capz
Rad_Capz HalfDork
7/21/14 8:41 a.m.
Might have been 70 for the change but the 460 doesn't fit well in a 68. I built one with a 460.
TeamEvil
TeamEvil HalfDork
7/21/14 12:06 p.m.
"If you pull the coil wire to the distributor and take that with you, that works, doesn't it?"
The V8 Ford engine comes stock with eight potential coil wires and runs quite well on seven cylinders.
But kids these days don't even know what's under the hood anyway, you're safe, don't worry !
RossD
RossD PowerDork
7/21/14 1:27 p.m.
I was reminded of this thread when I found this: http://milwaukee.craigslist.org/cto/4574027359.html 1967 Ford Ltd - $2500
So I thought that I should share.
Nitroracer
Nitroracer SuperDork
7/21/14 9:53 p.m.
I would bet it was 70' with the body style change. 68 and 69 are nearly the same.
I would be tempted to drop the full engine in from an explorer rather than toy with swapping heads.
belteshazzar
7/22/14 10:58 a.m.
that's exactly what I did into my '93 F-250. GT40p EVERYTHING!!!
belteshazzar
7/22/14 11:01 a.m.
but then why buy a 302c.i. motor for an engine swap, when there's a 460c.i. motor already sitting here? Rad_Capz, did you not use the crites mounts?
Rad_Capz
Rad_Capz HalfDork
7/22/14 12:07 p.m.
belteshazzar wrote: but then why buy a 302c.i. motor for an engine swap, when there's a 460c.i. motor already sitting here? Rad_Capz, did you not use the crites mounts?
I didn't install the engine. Someone else got it in the car and walked away. I built a 9" rear for it, power disc upgrade from drums, power steering from manual, aluminum radiator with electric fans, MSD ignition, Mallory Unilite, and rewired the whole car. Had all kinds of weird issues requiring the use of a March belt system, GM style PS pump, etc. Like I said, it CAN be done but I wouldn't do it if the 4 dr being discussed was my car. It would be a lot of expense and headaches for a car with very little resale value when done.
fT92OVULxQr3lOoEwvYfjmSHNysEaj6QWeLK4PJ6pum9N2Qnit9ysgwBDRYU2BuO
