Snrub
Snrub New Reader
3/28/14 7:47 a.m.
'03 Chevy Malibu spec is 284flbs for the original spec axle nut.
For the 13B eccentric shaft nut, find one that requires "only" 350ftlbs to remove. I recall jumping on a make shift 8' breaker bar to try to loosen one. The answer is often not "impact" but grinder...
Tom_Spangler
Tom_Spangler Dork
3/28/14 8:28 a.m.
RexSeven wrote:
Tom_Spangler wrote:
RexSeven wrote: The flywheel on an FC RX-7 has to be torqued down to 350ft-lb! You need one of these to make sure it can be torqued down or removed properly. http://www.racingbeat.com/RX7-1986-1992/Flywheels/22000.html
I still have mine! Bought it 15 years ago during my FB days. I don't know why I keep it, I'll certainly never own another engine with cursed spinning triangles. Unless I'm removing it to put a real engine in.
If you're willing to sell then there's plenty of us triangle voodoo practitioners that could use it.
It never occurred to me that it might be worth something. Thanks, I think I will!
Knurled
Knurled PowerDork
3/28/14 12:52 p.m.
Ian F wrote:
Knurled wrote: I just use good ol' 2135Ti to remove, then when installing, torque to 150ft-lb, mark the flywheel at one of the nut's points, mark the nut at the point directly counterclockwise from that, then invite Mr. 2135Ti back over to play connect-the-dots. Never an issue.
Not a great idea on single-use locking axle nuts...
That's for rotary flywheels.
Kenny_McCormic
Kenny_McCormic UberDork
3/28/14 2:35 p.m.
Vigo wrote: All those numbers sound like "impact" to me. But what do i know!
There's a reason the box the hub comes in has a big piece of paper telling you NOT to do that.
H90rWXnMNnbOMeLMhvplVEFTYiV7rwDVX3qVdZYx2uRh1hB3Iuma7eLjsSyaEWjO
