GTXVette
GTXVette Reader
12/12/16 11:33 a.m.
My friend had a water pump and related Heater parts installed and after its warmed up It will steadly push coolant out the overflow and overheats. Do they need to burp or is there a way to determine If its a Gasket or Cyl.cracked,I can do a cyl pressure test,But usually a gasket or cyl.leak makes a pulseing not just steady lite pressure,It's raining so just thought I'd ask before getting wet.
chaparral
chaparral Dork
12/12/16 11:39 a.m.
Yes, they need to be bled. I have the FSM for a '99 Vette at home but I don't know if your car uses the same procedure.
GTXVette
GTXVette Reader
12/12/16 11:48 a.m.
Lets go google, thanks, any one else ,something creative
itsarebuild
itsarebuild Dork
12/12/16 12:33 p.m.
Is the radiator cap good?
BrokenYugo
BrokenYugo UltimaDork
12/12/16 1:57 p.m.
itsarebuild wrote: Is the radiator cap good?
This, any car will boil over with nothing wrong other than a dead cap.
GTXVette
GTXVette Reader
12/12/16 3:20 p.m.
Yes the cap was first on the check list,Looks good,Rubber is soft,Really hard to screw on and off,so much so I bought a new one for 7 bucks,That fixed it,Need to put a few more miles on it though, so looking at the old cap, up inside where the pressure valve is,it looks corroded and no spring like movement,so far I don't see me making any money. thanks ya'll
OldGray320i
OldGray320i HalfDork
12/12/16 3:58 p.m.
Yeah, not always. On my name sake 320i, it was a warped head allowing cylinder gas in to the cooling system. Head gasket told that story (what a jerk HG...).
Said warped head supposed to have been checked at machine shop rebuild - but hard to prove when you take 3-5 years to get around to putting the motor together after picking up the head (I guess next time I'll straight edge and feeler gauge that sucker myself...).
BrokenYugo
12/12/16 5:07 p.m.
In reply to OldGray320i:
I'm not saying a dead cap is the only possible problem, but rather that a dead cap will always lead to overheating/boiling over/leaking out the overflow, that's just physics. Radiator caps are like the spark plugs of cooling systems, when in doubt you start there, or just always start there since its a cheap wear item.
GTXVette
GTXVette Reader
12/12/16 5:17 p.m.
Yeah had my Friend Let me make the Inital repairs a new Cap is ALWAYS on the menu,and I coulda made a few Bucks, 10 minutes and 7 dollars make it had to justyfy charging him.
OldGray320i
12/12/16 5:57 p.m.
BrokenYugo wrote: In reply to OldGray320i: I'm not saying a dead cap is the only possible problem, but rather that a dead cap will always lead to overheating/boiling over/leaking out the overflow, that's just physics. Radiator caps are like the spark plugs of cooling systems, when in doubt you start there, or just always start there since its a cheap wear item.
Ah, got it - I read it backwards... troof.
QTtr6NQrRJekezCRnAhx44I9FcFoyouDNoEbSNZBtjYc1TPOtoCmx7OhoGYeuwBO
