dean1484
dean1484 MegaDork
6/7/16 8:02 a.m.
Found a really nice 2002 but needs a trans. (has 180k on it) I also found a good used trans with less than 80k. Purchas price on both is under $1500.
So how hard is it to swap a trans in one of these. A weekend job in the driveway or is it a major job needing special tools and what not.
Grtechguy
Grtechguy MegaDork
6/7/16 8:15 a.m.
I would say an engine lift would be needed at minimum, but past that?
Javelin
Javelin MegaDork
6/7/16 8:36 a.m.
dean1484 wrote: I also found a good used trans with less than 80k.
Untrue. I guarantee that transmission either does or will need a rebuild soon enough after you swap it that you will hate yourself.
Also, it is not a driveway project. FWD transmissions are a pain in the neck. You need an upper engine cradle tool to hold the motor in and a 2-post lift to keep the van up while you use a trans jack (or 2) to drop the front subframe before you can even take the transmission out.
Javelin
Javelin MegaDork
6/7/16 8:37 a.m.
jfryjfry
jfryjfry New Reader
6/7/16 8:40 a.m.
Or.... Van on jackstands, motor supported by 4x4 across firewall and rad support or fenders with a strap or two and a jack under trans (floor or tranny).
Never done it on an odyssey so maybe there's a flaw but have done it on several others
gearheadmb
gearheadmb HalfDork
6/7/16 8:55 a.m.
Buyer beware. Internet lore says 80k is about the service limit on one of those trannys. They had so many problems with the transmissions that actual good ones are really hard to find.
Bobzilla
Bobzilla UltimaDork
6/7/16 9:30 a.m.
2 things, that used trans is a time bomb. No history, 80k it MIGHT last to the end of hte block, it MIGHT last a week. I wouldn't trust it past that.
secondly, the front subframe has to come out, with the LCA/s while the engine trans are supported up top. Then you can take the trans off the engine. there's no way to get it out up top and the only way it fits out the bottom is with the subframe out. IT's not an easy job.
codrus
codrus Dork
6/7/16 9:32 a.m.
The newer 06+ Odyssey transmissions seem to be much more reliable -- how hard is it to update to one of those?
markwemple
markwemple SuperDork
6/7/16 9:49 a.m.
Yeah, that trans is a POS! Either rebuild, or don't bother. You may get lucky but the original owner getting to 180 was really lucky. I'd say max life is 150k and I wouldn't trust that the other really has only 80k.
fireball123
fireball123 New Reader
6/7/16 11:54 a.m.
I think you should take it too the shop and get the transmission rebuilt because just like everybody else has been saying a junk yard transmission will ether be bad and last u a month or will be really bad and only last to the end of the block
airwerks
airwerks Reader
6/7/16 12:02 p.m.
Am I really the first one to say manual swap?
Grtechguy
Grtechguy MegaDork
6/7/16 12:27 p.m.
^^^^^ and then Turbo the crap out of it. Because 1029 HP is just enough.
dean1484
dean1484 MegaDork
6/7/16 2:08 p.m.
Hummmmmm Me thinks I will pass on this plan. I guess I should be looking from a post 2005
Vigo PowerDork
6/7/16 7:54 p.m.
Yeah, that's pretty standard and i got used to it pretty quickly when i did trans R&R for a living (eventually started building too). I actually look back on my trans r&r work as some of the most enjoyable automotive repair work i ever did. I really enjoyed working on a job that was long enough that you didn't have to worry about 'what's next' every 30mins and the complexity of the work (sometimes overblown) kept me engaged whenever i wasn't so practiced in a particular job that i just daydreamed through it.
But yeah, without a lift, not much fun.
OHSCrifle
OHSCrifle Dork
6/7/16 8:02 p.m.
If the trans fluid was ever changed, it could be just fine. Mine was fine when I sold it with 165k.
A major brand rebuild with warranty is about $3500 on one of these, and they're great vehicles.
I sometimes troll CL looking for these with bad transaxles, hoping to find a diamond for about $750 (a frustrated "get it out of here" sale, basically). Don't tell my wife.
fireball123
6/7/16 9:52 p.m.
Grtechguy wrote: ^^^^^ and then Turbo the crap out of it. Because 1029 HP is just enough.
Bobzilla
Bobzilla UltimaDork
6/9/16 9:40 a.m.
OHSCrifle wrote: If the trans fluid was ever changed, it could be just fine. Mine was fine when I sold it with 165k. A major brand rebuild with warranty is about $3500 on one of these, and they're great vehicles. I sometimes troll CL looking for these with bad transaxles, hoping to find a diamond for about $750 (a frustrated "get it out of here" sale, basically). Don't tell my wife.
OE remans with 3yr warranty on in the same price range.
jjpDAQwdVBgLI8frjh63zOuxz3FO01YIPCVCPKQZikTIFUQLzbSOMPBehOcN8qFb
