OldGray320i
OldGray320i HalfDork
7/4/16 10:54 p.m.
So, drove my friends truck, at any point in steering wheel rotation, it feels like it loses power steering, and semi locks up.
Usually a little back and forth play with the wheel gets it moving again.
No obvious leaks anywhere, ps fluid looks a little dirty, rack boots are split and a little dirty in the tie rod joints, but I can't see anything that would cause the steering to stick as hard as it does.
Help.
Run_Away
Run_Away HalfDork
7/4/16 11:24 p.m.
How long has it been run with split boots? I'd check the rack for play.
Ranger50
Ranger50 UltimaDork
7/5/16 5:55 a.m.
Steering shaft has froze joints.
Streetwiseguy
Streetwiseguy PowerDork
7/5/16 7:56 a.m.
Ranger50 wrote: Steering shaft has froze joints.
Certainly a good place to start. If you roll the wheel from stop to stop, and it goes stiff/free/stiff/free with each rotation, head directly to the steering shaft.
OldGray320i
7/5/16 11:42 a.m.
That's probably the best description, but is it likely to be at the top, or down closer to the rack? Closer to the rack looks pretty basic, and I don't think I've ever had an old car with that issue (which, isn't saying that much...).
Top end is buried under a cover (and behind the booster...), does not look like fun to get to. And it seems like that's a pretty significant angle that it operates at, as steering columns/shafts go.
Ranger50
Ranger50 UltimaDork
7/5/16 11:55 a.m.
If there is not a bolt near the cover to undo the upper part of the shaft, it's on the other side of the boot above your feet.
Most likely, the box/rack end is at fault. Undo it at the box and try to rotate it around. I bet you find it sticks.
nzoYOUHNMIduhyeuCh4lT2sFFIFuSOFU8VyzmMrBWvLfFuPrAK4G2dfnYN31PGlI
