vazbmw
vazbmw HalfDork
1/7/14 9:10 a.m.
Hi Folks A friend asked me what I thought, and I had no idea. I have not seen the vehicle, but it is about 5 degrees outside right now. He said he went to drive his car and the steering would not unlock and the check charging system light was on. That vehicle has about 1000 miles on it. Do you guys have any ideas what could be up with this vehicle? I suspect the battery voltage dropping to low because of the extreme cold. He says there is no key. Steering unlocking etc is done electronically.
Thanks for any ideas
Ranger50
Ranger50 PowerDork
1/7/14 9:17 a.m.
Think you have it nailed.....
iceracer
iceracer UberDork
1/7/14 9:51 a.m.
Have Ford tow it in and fix it.
ultraclyde
ultraclyde SuperDork
1/7/14 10:35 a.m.
It does sound like a low voltage condition, but even 5 degrees shouldn't directly cause that unless a component failed that shouldn't have. They are designed to run in much colder temps. In any case, whatever broke should be a warranty item, so iceracer's right.
side question - you didn't say in your original post - did the engine start and run?
vazbmw
vazbmw HalfDork
1/7/14 10:41 a.m.
The engine did start…Sorry I left that out. That is the part that threw me for a loop
NGTD
NGTD Dork
1/7/14 10:50 a.m.
Must be a Limited - they have the no key "start button". If the engine started. I can't see why the low voltage would stay.
I think the other poster is right - tow truck to the service bay!
vazbmw
vazbmw HalfDork
1/7/14 10:54 a.m.
This is a mystery. He is having it towed to Ford to see what they say. I will update once I hear back. I haver never heard of something like this before.
Ranger50
Ranger50 PowerDork
1/7/14 11:00 a.m.
I have had a few Fords where the crimps in the connector aren't seated properly. This could be a BCM programming issue too.
vazbmw
vazbmw HalfDork
1/7/14 11:04 a.m.
What is BCM? Body Control Module?
Ranger50
Ranger50 PowerDork
1/7/14 11:19 a.m.
In reply to vazbmw:
Yes.
bgkast
bgkast Dork
1/7/14 11:24 a.m.
Dang newfangled cars with their no keys and push button start.
/get off my lawn
vazbmw
vazbmw HalfDork
1/7/14 12:05 p.m.
Give me a key, throttle cable, rack, pinion brakes with hydraulic fluid and I am set LOL
bgkast wrote: Dang newfangled cars with their no keys and push button start. /get off my lawn
vazbmw
vazbmw HalfDork
1/10/14 2:36 p.m.
Update: Diagnosis from dealer was a bad alternator. Wow, new cars and their fancy electric stuff
tz23yZww6Vb3AOzz5BZygJlTRpS4zsDXtyQjxSzt21CtGq5ELEvUHym8fNLghmtL
