KyAllroad (Jeremy) (Forum Supporter)
KyAllroad (Jeremy) (Forum Supporter) UltimaDork
9/27/20 7:24 p.m.
The internet isn't very clear today.  Some of us were discussing the cannonball runs of late and I was reminded of those records manufacturers used to set at big oval tracks where they could run their cars flat out for 24 hours and set various records.  I remembered Saab did it in the 80's.  The internet says Corvette did it in the early 90's with a ZR-1 and averaged something like 175 mph for a full 24 hr day.   Apparently VW ran their prototype W12 supercar in the early 2000's to a 200 mph average.
Were they the last ones to set and hold the record?  My google-fu appears weak. Seems like something that should be brought back.
Streetwiseguy
Streetwiseguy MegaDork
9/27/20 7:36 p.m.
Just a guess, but maybe Nurburgring numbers are more fashionable now.
Purple Frog (Forum Supporter)
Purple Frog (Forum Supporter) Reader
9/27/20 8:46 p.m.
One problem the engineers face now is tires.  The cars are so fast and the tracks to use have banking, so loads on tires are great.
A few years back I heard that insiders at IMSA wanted to set a closed course record possibly using a prototype at Daytona or Talladega.  It became obvious there was not a left rear tire that would hold up, and fit a prototype.
akylekoz
akylekoz SuperDork
9/27/20 9:23 p.m.
I can in second place at Joliet after twenty four hours with a four cylinder Mustang.  Must be some sort of record.
j_tso
j_tso Reader
9/27/20 10:56 p.m.
probably depends on who officiates the record, but the FIA does the ones I hear about.
https://www.fia.com/fia-world-land-speed-records
Looks like nobody has topped the VW W12 yet.
LanEvo
LanEvo Dork
9/28/20 9:29 a.m.
In August 1983, Mercedes broke a bunch of world records at Nardò to promote their first-ever compact chassis: the W201. They ran 190E 2.3-16 Cosworths with manual transmission. The big headline was 50,000 km in 201 hours (W201 ... get it?).
Continuous 6000 rpm for 9 days straight in 104 degree weather. 150 mph average speed (including pit stops every 50 minutes). The cars were mostly stock. Every 8,500 km, they had a longer (5-minute) pit stop to swap rear tires, do an oil/filter change, and check valve clearances. Front tires were swapped at every other 5-minute swap (17,000 km).
Only one of the three cars had a mechanical failure:  a broken Bosch distributor arm. According to FIA rules, they weren't allowed to replace it, so the techs were forced to repair it.
Robbie (Forum Supporter)
9/28/20 10:42 a.m.
In reply to LanEvo :
distributor ARM? is that the cap or is that the shaft? maybe something else?
CrustyRedXpress (Forum Supporter)
CrustyRedXpress (Forum Supporter) Reader
9/28/20 10:59 a.m.
Spiny bit under the cap, also called the rotor.
I love the Nardo story, first time I'd heard that they had to check the valve clearances. What a PITA if the clearances were off on that engine!
9/28/20 11:01 a.m.
rotor, duh. That's what I meant by cap. geez im a mess this morning.
plIIwTnTuaMKSx3nwHdh8XmMrgO4k9e8nrFCuSH9McUiZ7NuL4XyU9Y1SpV8S6Wq
