Beast of Turin....
http://vimeo.com/113158655
now if we had a thread about intimidating exhaust pulses... this thing might win
Beast of Turin....
Saw this on the interwebz yesterday.. Glorious and downright frightening even over headphones, I love it!
I knew exactly which car you were talking about when I saw the title. You can see one of the pistons at the 44sec mark - it's the size of a paint can
So when does Jay Leno buy this beast?
Am I the only one that squinted and half-turned away when the exhaust flames shot out at the camera?
GameboyRMH wrote: I knew exactly which car you were talking about when I saw the title. You can see one of the pistons at the 44sec mark - it's the size of a paint can![]()
before I watched the video i thought, spray paint can sized piston? thats not huge, this thing must have like 80 cylinders. then I saw it...
bearmtnmartin wrote: I squinted and turned away when I saw him go to hand crank it.
Hand cranking isn't bad, but you do need to do it right every time. I hand crank all my antique engines. My 12 hp LeRoi is the worst of them and I won't let anyone else start it. It's snatched the handle out of my hand several times, but never bitten me. The pistons on it are about 4". The 3 hp has a bore in the 5" range, but the flywheels are so big that inertia keeps it in check.
28L on the other hand would be terrifying. I'd still try it.
Yes. I like how one of the mechanic dudes is wearing a tie the whole time he was working on it. God help me if I own a car in which I can do that.
I should film my build with artsy focus set to soft piano music....it really classes it up.
Fantastic car, glad I wasn't the one cranking it!
Gearheadotaku wrote: Is the crank loading a spring to start it? He lets go and steps away before it fires up.
It might be a case of prime it, roll it up on compression, set piston at ATDC, add ignition. I kind of wondered the same thing.
Than again, most of my engines fire after I've already turned the handle loose.
Time for you to look up Detroit 24-71s.
24 Cylinders, 71 cubic inches each.
Toyman01 wrote:Gearheadotaku wrote: Is the crank loading a spring to start it? He lets go and steps away before it fires up.It might be a case of prime it, roll it up on compression, set piston at ATDC, add ignition. I kind of wondered the same thing. Than again, most of my engines fire after I've already turned the handle loose.
I watched it a couple of more times and it looks like he's pulling it across TDC on the compression stroke. Then you hear someone say something and it fires. I can't quite understand what he's saying, but it sound like "gas it."
bgkast wrote: I say carbon bits. I'm thinking that isn't the most efficient engine in the world.![]()
Gallons per mile. But in the "Beast of Turin," I'd say those are gallons well spent.
it is fairly advanced for being 114 years old. 4 valves per cylinder and an OHC.. this was before most car makers were even a gleam in their creator's eye
