Fitzauto
Fitzauto Dork
3/17/19 10:59 p.m.
When building a 3 link on a live axle, how important is it for the 3rd link to be centered? Will it affect handling it’s it’s off center?
ChasH
ChasH New Reader
3/17/19 11:12 p.m.
Not important-what locates the axle side to side?
alfadriver
alfadriver MegaDork
3/18/19 6:23 a.m.
Actually, putting the third link offset to the side that would be lifted due to input torque, you can use the device to reduce or eliminate torque wedge.  There have been some old articles in Racecar Engineering and I think there was a dedicated thread on Corner Carvers that discusses it.
slowcamaro
slowcamaro New Reader
3/18/19 7:38 a.m.
this may at some time save you some searching
http://www.shopeshop.org/tim.19.htm
alfadriver
alfadriver MegaDork
3/18/19 7:50 a.m.
I saw a similar calculation page many years ago- but that's exactly what I was thinking.
Fitzauto
Fitzauto Dork
3/18/19 10:21 a.m.
That’s the kind of info I needed. Thanks!
GTXVette
GTXVette UltraDork
3/18/19 11:37 a.m.
Billy Shopes Was an Original RamCharger, Chrysler Engineer And was A Factory Team Member, I Haven't Looked In Years but when Any Chassis Questions come up He has Been Their Done That /With Factory Secrets Galore(For the Sixty's)  So Read Billy's Stuff And Belive me It Works.
GTXVette
GTXVette UltraDork
3/18/19 11:43 a.m.
Explain to me Why NOT. , What or How You Mount A Watts or Panhard Does Matter But Not Nearly as Much As the Lateral Links and Now If you will Go Back and read About Any Chassis book You May see why . Not Trying to be mean but It's of the Utmost Importance.
ChasH
ChasH New Reader
3/18/19 12:04 p.m.
First off, we are discussing the upper link. It doesn't matter because it's an solid axle on street tires. Jaguar used an upper link on the right side of their 120C. Alfa uses an upper link on the left side. If you want a further discussion drop the attitude.
GTXVette
GTXVette UltraDork
3/18/19 1:03 p.m.
sorry,  I Was In Shock    And I did Say 'Not To Be mean".We Were Answering a Question About An Upper link , and everything from Where it's Mounted to How High Above CL of the Axles to How far Downward/ Angle to where it's Pointing (center of Gravity).and Left or right will Come into play, And also the Lower Links Have these same Functions,By Adj. them you can Make a car Stand on the Back Bumper Or Not be able to Lift the wheels off the ground,The Upper location can also Induce or Eliminate Torque Steer
Fitzauto
Fitzauto Dork
3/18/19 1:30 p.m.
I’ll be using the stock panhard bar for side-to-side location.
ChasH
ChasH New Reader
3/18/19 1:40 p.m.
Have you given thought to the bushings on the ends of all the axle locating parts?
Fitzauto
Fitzauto Dork
3/18/19 2:04 p.m.
In reply to ChasH :
Currently heim joints on all ends of the 4 link and panhard.
ChasH
ChasH New Reader
3/18/19 2:11 p.m.
Fitzauto said:
In reply to ChasH :
You currently have a 4 link rear?
Fitzauto
Fitzauto Dork
3/18/19 2:19 p.m.
In reply to ChasH :
That is what the car had stock. Swapping in a 8.8 axle.
wawazat
wawazat HalfDork
3/18/19 2:47 p.m.
Not a canoe but I am a Street or Track customer.  Link has some pics/video of Shawn's three link system and the installation.  It may be helpful.
http://www.streetortrack.com/Street-or-Track-Rear-Bilstein-3-Link-System-pr-24572.html
ChasH
ChasH New Reader
3/18/19 3:41 p.m.
Fitzauto said:
In reply to ChasH :
Why not go with the 4 link?
Fitzauto
Fitzauto Dork
3/18/19 5:26 p.m.
In reply to ChasH :
Has a tendency to bind up. Options are either equal length upper arms or 3 link, which I’ve been told works a little bit better when designed right.
snailmont5oh
snailmont5oh Dork
3/18/19 6:06 p.m.
The upper arm on the 3-link in my Fairmont is just slightly off-center to the right, most likely for packaging. The axle mount for the upper arm on my '71 full-size Ford wagon is the same piece of steel that the Panhard rod mounts to, so it's pretty far right. It's not terribly important where a single upper link is, but right is better than left, if the engine turns counter clockwise.
ChasH
ChasH New Reader
3/18/19 6:14 p.m.
Fitzauto said:
In reply to ChasH :
Yup, the 4 links need to be equal length if the ends are "Heim" joints. You can help that by using urethane bushings in an upper link.
freetors
freetors Reader
3/18/19 6:15 p.m.
Fitzauto said:
In reply to ChasH :
There are some installations of four links that could bind, but those are really more because of poor detail design. A double-triangulated four link or satchell link with eight rod end bearings WILL NOT BIND, all the way up until the individual rod ends reach the limits of swivel travel. And an added bonus is that you don't have lateral axle motion from a panhard. You might be surprised to learn that the fastest autocross car in the country is using a satchell link suspension.
It really isn't even more work to do a four link vs three link w/ panhard.
freetors
freetors Reader
3/18/19 6:16 p.m.
ChasH said:
Fitzauto said:
In reply to ChasH :
This is just wrongity wrong.
snailmont5oh
snailmont5oh Dork
3/18/19 6:35 p.m.
freetors said:
ChasH said:
Fitzauto said:
In reply to ChasH :
I concur. Urethane on your 4 link is exactly the worst thing if you're trying to avoid bind.
ChasH
ChasH New Reader
3/18/19 6:55 p.m.
snailmont5oh said:
freetors said:
ChasH said:
Fitzauto said:
In reply to ChasH :
Well, what would you experts recommend then?
Knurled.
Knurled. MegaDork
3/18/19 7:37 p.m.
The more compliant the bushings are, the more you will notice the link being off center because the torque will be resolved more towards one lower link than the other instead of equally, so that side's lower will compress more under load.
Also, instant center will be dependent more on which direction the body is rolling.  I also have a gut feeling that the instant center will affect that SIDE more than the other, but I could be wrong.
So, yes, you do kinda want to get it as centered as space will practically allow.
qsBqNTCmNg5nHp6sIaXqFtbvITrR8fp9teQdRyQIiUIYj68oeFe5VS0nvezJVHA1
