Suprf1y
Suprf1y PowerDork
3/1/18 5:29 p.m.
I commuted for years in a Swift/Metro/Firefly concoction and was plenty comfortable - and I'm still alive!
Just think of all the money he would be saving on fuel
slefain
slefain PowerDork
3/1/18 6:38 p.m.
Psst, I own this one:
VWGuyBruce built it for the Challenge a few years ago. It isn't fast by any means, but corners are fun. Still won't pass emissions though.
DrBoost
DrBoost MegaDork
3/1/18 7:19 p.m.
Nick Comstock said:
I haven't seen the car yet. What's the worst case scenario?
It's a Geo Metro. That IS the worst case scenario.
Nick Comstock
Nick Comstock MegaDork
3/3/18 4:27 p.m.
Knurled.
Knurled. MegaDork
3/3/18 5:16 p.m.
And so it begins.
Dusterbd13
Dusterbd13 MegaDork
3/3/18 5:45 p.m.
I love this place.
SkinnyG
SkinnyG SuperDork
3/3/18 7:07 p.m.
Still waiting for the Firebird on the trailer.
Pete Gossett
Pete Gossett MegaDork
3/3/18 7:17 p.m.
In reply to Nick Comstock :
I'm jelly
Nick Comstock
3/3/18 7:26 p.m.
I need to do a proper compression test but was able to get it to run and idle for a couple minutes. Needs radiator, all hoses, all belts and all rubber brake lines to start with. No rust so that's good. I got a little aggressive strapping the rear wheels down and bent the rear toe links. Local pick and pull has three in the lot so hoping to find those there. Drove it on and off the trailer but took a lot of revs and a lot of slipping the clutch.
Suprf1y
Suprf1y PowerDork
3/3/18 9:05 p.m.
That car could have an advanced timing sprocket on the cam. I think I sent him one just before the challenge, and being the heaviest of the Metros it would have been a +10. If that's the case, it would certainly affect your emissions, and they often ran very close to the edge of the emissions limits.
That's a fugly Metro.
barefootskater
barefootskater Reader
3/3/18 9:13 p.m.
I'd bang it.
vwcorvette
vwcorvette SuperDork
3/3/18 9:14 p.m.
I owned one and had a burnt middle cylinder exhaust valve twice. Finally sold it.  Was fun to drive for what it was but didn't want to risk another valve job.
Grizz
Grizz UberDork
3/3/18 10:38 p.m.
RealMiniParker
RealMiniParker UberDork
3/3/18 11:40 p.m.
In reply to Grizz :
I was thinking the same thing. devil
Nick Comstock
3/5/18 6:28 p.m.
I'm very much convinced the timing belt has skipped a tooth.
However we've got other issues. Pretty low compression. Cyl 1 120 dry 135 wet, cyl 2 120 dry 135 wet, cyl 3 90 dry 120 wet.
I can live with 1&2. 3 is worrisome.
Regardless I'm pretty confident that it'll get to the Grand canyon and back.
I got a better look at the rest of the car and the chassis is very solid.
Suprf1y
Suprf1y PowerDork
3/5/18 6:35 p.m.
Did you hold the throttle wide open when you did the compression test? It can make a big difference on those.
Worst case you can re-ring and rod bearing with the motor in the car in an evening
MrChaos
MrChaos Dork
3/5/18 6:51 p.m.
im 90% sure you dont need a hoist to take that engine out.  The engine fully dressed weighs like 120 lbs and the trans weighs like 50 lbs.
Nick Comstock
3/5/18 6:53 p.m.
In reply to Suprf1y :
Dang, I knew I forgot something. I pulled the fuses so I could hold it open but totally forgot to do it.
I'll check it again once I get the timing belt changed. Or maybe I'll check it again tomorrow.
Suprf1y
Suprf1y PowerDork
3/5/18 7:35 p.m.
Trans is 65 lbs. I've shipped enough I don't even weigh them anymore
Robbie
Robbie PowerDork
3/5/18 8:51 p.m.
Timing belt probably affects overall compression numbers. Shouldn't affect the relationships between the cylinders, but if the timing is off you might get low readings.
Nick Comstock
3/5/18 9:07 p.m.
In reply to Robbie :
I was thinking that may be a factor as well.
PS, hoping to have some results for you by this weekend.
Robbie
Robbie PowerDork
3/5/18 9:18 p.m.
you are awesome!
WonkoTheSane
WonkoTheSane Dork
3/6/18 12:07 a.m.
Time to visit the cheap turbo thread in the 2018 for sale section?
NickD UltraDork
3/6/18 7:13 a.m.
Buy a second Metro and do like Citroen did when they needed to make the 2CV into a 4WD and mount a second drivetrain in the rear.
fanfoy
fanfoy Dork
3/6/18 9:00 a.m.
I've always wanted to get one of those and transform it into something like a Festiva Shogun...
iEKlk72aTtvzvWU7sF1A0Zp3w4X59VTMTmPk3cuJpOoa5ypBqACD8sBrXJoiRgDD
