psychic_mechanic
psychic_mechanic Dork
11/14/13 4:15 p.m.
I'm trying to get my 3SGTE to spark using the stock distributor and microsquirt, but it's not working yet. Using MS Tune fro the tuning part. I've removed two teeth from the trigger wheel as suggested. I think I've set all the parameters correctly but couldn't find the "skip teeth" box in my menus.
I used this as a go-by, but my ignitor harness doesn't have an Ne wire so I tried using the one from the distributor with and without a 12V kick-up.
I've got it wired like:
Any ideas or directions towards information to cover this?
psychic_mechanic
11/14/13 4:27 p.m.
Looking around a bit more it looks like my engine doesn't use VAST, it uses ESA, so off to do some more research.
psychic_mechanic
11/15/13 3:32 p.m.
Got it to spark!
I used the VR inputs instead of the OPT, The OPT is for square waves and the VR sensors in my distributors produce regular waves and have to be conditioned inside the Microsquirt to trigger eveything.
Birthdays
NZPLpKSQWM7RuFeeHmADtdkDUwK8LYougE9X2Vwu9ptYzByvvVxvKpiqdM2JpokB
