alfadriver
alfadriver SuperDork
11/13/11 6:29 p.m.
I see ZSD-424 as the engine, which according to a wiki page for Duratorq engines has that as a 2.4l I4, 99hp, 210 lb-ft.
Interestingly enough, searching for Ford Power Products does not bring up that particular engine. None of the distributors even have a 4 cyl diesel enigne- all are gas or natural gas.
So it must have been sourced from Europe for who ever bought it.
It's not going to move quickly, with 99hp.
alfadriver
11/13/11 6:31 p.m.
Brocure- http://www.i-m-a.de/pdf/Ford/diesel_engines/ZSD_424_Sales_Leaflet_4_2003.pdf
dean1484
dean1484 SuperDork
11/14/11 6:13 a.m.
They were using harnesses and ecu's from ford. I was told you give ford the numbers off the motor and they can sell you them.
RossD
RossD SuperDork
11/14/11 7:46 a.m.
I wonder if it's the classic ford 4 cylinder bellhousing pattern or a SAE pattern or something else...?
MadScientistMatt
MadScientistMatt SuperDork
11/14/11 8:33 a.m.
dean1484 wrote: So can MS run a turbo diesel?
Not yet. We've kicked around the idea of trying it but it will take some new injector drivers for the direct injection control, at the very least.
alfadriver
11/14/11 12:38 p.m.
If you do, be aware that unlike normal PFI injectors, the different manufactuerers have different driver outputs. Total PITA. BUT, if you were going to start with one, Bosch seems to be more the mareket than Denso. And I don't know if the gas DI drivers are the same as diesel.
Injecting at 200-2000psi or 2000-20000 psi sure has changed things.
erohslc
erohslc Reader
11/14/11 3:25 p.m.
Many (maybe all) Diesel injectors use piezo technology, which requires higher voltages (>100-200V). But unlike the solenoid type injectors, which are basically either fully open or fully closed, some of the piezo types can be modulated to control how much they are opened. This can allow for controlled longer duration fuel delivery, contributing to more efficient burn tha dumping it in all at once.
Carter
HFZgDBvl2WZPeX3KfyhmtrzRIjBjSaEjMoJNAVMrspTDl01SSnxamKGJsXbmpGFC
