So last week I ended up getting a call late at night the the transmission in the 1998 Ram was acting up.
When you got to about 20-25 it would try to shift to second, but then change back to first and then second, but never really committing to either gear. Fluid was slightly low (just below the safe range), topped it off and no improvement.
After waiting over an hour (it was now 1:30am) for AAA to even say that some had dispatched a driver, I gave up. I had my son cancel the call to AAA, and said I'd drive it home.
I experienced the issue he called me about as soon as the truck reached 15-20 and tried to shift. After pulling into a parking lot, I squeezed myself under it far enough to unplug the remission harness connector.
I then drove it home manually shifting between 2nd and 3rd with no slip regardless of throttle or hills.
Based on the behavior and research it looked like the governor solenoid and sensor were the culprit. This weekend we replaced them, put in a new filter and fluid, then cleared the codes. Took it for a test drive and it was better, but no OD or lockup and once warm it started to do the same thing. Unplugged the harness and got back home in limp mode.
As a Hail Mary we disconnected the battery and turned on the headlights and let it sit for about 5 minutes. This time in the test drive it was better, but still not right. There was none of the indecision on the 1-2 shift, but no kickdown (TV cable is adjusted correct and moves smoothly), and not OD.
Called it a night and unplugged the battery and left it overnight. Yesterday morning I reconnected the battery and took it for a test drive. I got excited when it had all gears and the torque converter locked up during the first 2 miles of the test drive.
That was short lived. When I reached the service road for the highway to started acting up, and I ended up unplugging the harness again to get home without abusing the trans with the incomplete shifts. At least I had the forsight to put some 2x6 blocks in the bed so I could raise it up and make it easier to reach the harness plug.
Anyone have any experience with 46RE transmissions and what I might want to look at?
I have an appointment for next Tuesday with a local transmission shop. I'm done with the parts cannon since next steps would be replacing the harness and remaining solenoids, replacing the valve body, or trying a Transgo kit, but none are guaranteed to work and ATF+4 isn't cheap.
If I can do something simple and not have to drive my son to his new job until next week, that would be great. The local ford dealers final day before closing was last Friday and he started at a nearby infinity dealer today. I'm sure not having transportation is just adding to the stress of starting a new job.
