Moparman
Moparman New Reader
2/5/09 8:55 p.m.
I know bolt-pattern-wise, 4x100mm BMW wheels wheel fit my 84 Dodgde Charger, but I am worried about the center bore hole. I know plder fwd VW wheels have center holes which are too small for the Dodge hub. Anyone have any info on this?
Jamesc2123
Jamesc2123 New Reader
2/5/09 9:14 p.m.
E30 BMW wheels have the same tiny center bore as older VWs, but i think most other bmws have much larger CBs. What are the BMW wheels you are looking at off of?
Moparman
Moparman New Reader
2/5/09 9:23 p.m.
Just exploring potential Grassroots wheel options
Carson
Carson HalfDork
2/5/09 9:34 p.m.
Most machine shops should be able to help you out if you need a larger center bore.
Lof8
Lof8 New Reader
2/5/09 10:15 p.m.
"xxr" wheels on ebay are cheap and have some 4x100 options. most are 8" wide and have offsets of 15 or 0.
Salanis
Salanis SuperDork
2/5/09 10:24 p.m.
Civic and Integra wheels have a fairly large center bore for OEM wheels.
SportMaxx is also popular for a decent cheap wheel. Actually, pretty much any aftermarket wheel will have a larger center bore so that they can fit anything.
Just hit craigslist and buy some use Rotas.
16vCorey
16vCorey SuperDork
2/6/09 7:34 a.m.
Salanis wrote: Civic and Integra wheels have a fairly large center bore for OEM wheels.
Not true. The Honda center bore is smaller than the VW.
mw
mw Reader
2/6/09 7:56 a.m.
for a grassroots approach, you can enlarge the centre hole with a dremel, die grinder, or hole saw. Just make sure you go big enough that the new hole is big enough that it doesn't matter if it is on centre.
bam2002
bam2002 New Reader
2/6/09 9:39 a.m.
The offset is what will get you.. The BMW e30 is a 25 to 28 offset.
All the Honda and VW wheels are for Front wheel drive. vs RWD.. The dodge would do better with the honda VW wheels .
rGhQMEMG580yUEGydjpWnOEkaWtCVfPfe8ZsGo8D6VDBtiqCY8dmpZpwRcIHgkgc
