msnglnk
msnglnk New Reader
3/18/10 7:28 p.m.
hi i have a 1983 rx7 and i put a widebody kit on and now need some tires and rims to fill the wheelwell. i have alum, 13x7 in the front and 13x8 in the rear and a lot more room for tire both up and across, does anyone know where i can get either some 15 inch rims to fir or would you recomend using adapters to put something else on thank you
aussiesmg
aussiesmg SuperDork
3/18/10 7:46 p.m.
Those 4 x 110 rims are notoriously difficult to find, try on www.RX7club.com
ZOO
ZOO Dork
3/18/10 9:54 p.m.
Konig Rewinds come in 4 x 110. I believe my father purchased his from Good-Win Racing.
Mazdax605
Mazdax605 Reader
3/18/10 10:01 p.m.
The Konig Rewinds are usually in a rather large plus offset,and not the negative offset that the RX-7 with a wide body kit needs.
P71
P71 SuperDork
3/18/10 11:10 p.m.
Konig makes a 0 offset 4x110 wheel called the B-Bomb in 15" sizes. I saw a gold center/polished lip set on a Mariah kitted FB once. Very nice wheels!
unevolved
unevolved Reader
3/18/10 11:11 p.m.
It's hard to find wheels in the right offset in 4x110, let alone the right offset for a widebody car. I'd recommend you spend the money to switch to 5x114.3 and all your wheel searching issues will disappear.
aussiesmg
aussiesmg SuperDork
3/19/10 7:41 a.m.
Or an easier install is 4 x 113 from a 84/85 GSL-SE which also opens up a lot of wheel choices, and gives you bigger rear rotors.
Downside is most of this lug pattern is FWD offset, but still many more options than the lonely 4 x 110
rmarkc
rmarkc Reader
3/19/10 7:18 p.m.
Are you looking for rimz to fill the space or something with a purpose other than bling? Doesn't diamond racing offer widths and offsets in 4x110?
Toyman01
Toyman01 Dork
3/19/10 9:08 p.m.
The last set of wheels I got I had built by Marsh Racing. Diameter, width, offset, and bolt pattern of your choice. Off the top of my head they were about $65 each.
http://www.mrt-wheels.com/
Jeff
Jeff Dork
3/19/10 9:35 p.m.
Toyman01 wrote: The last set of wheels I got I had built by Marsh Racing. Diameter, width, offset, and bolt pattern of your choice. Off the top of my head they were about $65 each. http://www.mrt-wheels.com/
Great link, thanks!
paW7v144VO2rbTDHYIeYdOCeATBfS22qVk0FP711G1Z7fjsmNhiac1LXqgEtYGMj
