AutoXR
Reader
12/28/09 4:29 p.m.
We are looking at converting the LS1 Corvair to a Hydraulic clutch setup. I can't seem to find any info on such a project , although I am sure it has been done considering the use of the transmission in GT 40 kit cars and sandrails.
Any ideas?
Thanks!
JM
Charlie Friend has a 930 transaxle in his ORR Corvair, but I don't know about the clutch setup.
cwh
SuperDork
12/28/09 5:18 p.m.
That thing has PLATES on it? Road legal? Wow.
AutoXR
Reader
12/28/09 8:14 p.m.
I have done a lot of reading on charlies car, it's a cable setup. I think I found a solution thou.
Thanks
The GT40 and sandrails are starting to use Audi transaxles (same as the 944's) and those are hydraulic.
Well if its a cable operated, can't you just maintain the clutch fork and actuate it with an external slave cylinder?
911s of similar vintage use a hydraulic setup. It's been a few years since I touched a porsche so I don't recall if they're interchangeable or not.
Big help, I know.
the audi transaxles are the same as the 944's?
You might find the ratio on the clutch fork is different.
We did this with a 4A-GE Toyota Starlet. Used the Starlet cable to pull the T50 clutch fork. The ratio was quite a bit different, the clutch pedal was very stiff and more like an on/off switch than a proper clutch.
It took some getting used to. We finally converted to a hydraulic clutch when the pedal broke.
Shawn
You'd need to use the same size cylinder at the master and at the slave. Then its linear movement is 1:1 just like a cable. The mechanical advantage is still at the clutch fork. Nothing really should change with regards to pedal feel. Its just a thought.
Yep, more or less.
Some linkage:
016 was used in the Audi 5000, 944, 924S and later 924's.
http://www.lambolounge.com/chassis/Transmission/5000/5000.asp
The newer version is the 01E and was used behind the Audi V8's, etc.
http://www.elektro.com/audi/01e/
And then there is the Audi 01X which is the newest, strongest, etc but isn't repairable at the moment and finding a FWD only version of either the 01E and 01X looks to be pretty tricky.
Apparently the Boxster uses a variation of the 016, the 012. It isn't as strong, but opens interesting possibilities in my head for cheap/easy engine swaps.
Anyway, sorry to hijack the thread so badly.
this brings up a related question.. as I want to use a porsche transaxle in a car.. is the 968 tranny availible as a 6 speed?
Yep:
http://en.wikipedia.org/wiki/Porsche_968
