Supercoupe
Supercoupe Reader
7/14/10 12:38 p.m.
what can I do to a Prizm to make it go??
4cylndrfury
4cylndrfury SuperDork
7/14/10 12:41 p.m.
push the one on the right all the way down with your foot until it touches the floor
madmallard
madmallard New Reader
7/14/10 1:08 p.m.
a-cha cha cha
mndsm
mndsm HalfDork
7/14/10 1:14 p.m.
it's a 94.... so you have some options. I've seen em swapped with a 7afe single cam, and turbo'd. Apparently the parts are out on eBay (I haven't looked, the last thing I need is another turbocharged E36 M3pile). AE101 chassis was also the last time you could fit a 4ag in it.... and the performance mods are well documented. There was limited TRD support for that chassis, so if you can find Corolla bits from the same gen (93-97) they should bolt right up.
96DXCivic
96DXCivic Dork
7/14/10 1:18 p.m.
From what I understand anything that fits the seventh generation Corolla will fit a Prizm.
Supercoupe
Supercoupe Reader
7/14/10 1:51 p.m.
nice...just picked one up for 225 and wasn't sure what to do with it.
93celicaGT2
93celicaGT2 SuperDork
7/14/10 1:53 p.m.
mndsm wrote: it's a 94.... so you have some options. I've seen em swapped with a 7afe single cam, and turbo'd. Apparently the parts are out on eBay (I haven't looked, the last thing I need is another turbocharged E36 M3pile). AE101 chassis was also the last time you could fit a 4ag in it.... and the performance mods are well documented. There was limited TRD support for that chassis, so if you can find Corolla bits from the same gen (93-97) they should bolt right up.
That'd be interesting... how does one make a 7afe single cam?
You can do pretty much anything to it. What do you want to do?
Dr. Hess
Dr. Hess SuperDork
7/14/10 1:56 p.m.
The 7AFE is a twin cam motor.
How fa$t do you want to go? 4AGE 20 valve will bolt in. Or turbo what's there, or put a 4AGZE supercharged motor in, or make a 7AGTE 20 valve turbo, or swap in a 3SGTE or ... push it out the back of a C130.
nocones
nocones Reader
7/14/10 2:08 p.m.
Seeing as how it's only the swap of 1 letter for 1 number away from gods own motor you know what must be done.
mndsm
mndsm HalfDork
7/14/10 2:59 p.m.
Goddammit, I keep getting my toyota engine nonclementures mixed up. I need to stick to DSMs.
Appleseed SuperDork
7/14/10 3:11 p.m.
Supercoupe wrote: nice...just picked one up for 225 and wasn't sure what to do with it.
Rally-cross.
Supercoupe
Supercoupe Reader
7/14/10 3:36 p.m.
I had wanted to use the engine and trans for my challenge car but it seems to good to hack up. Maybe I'll just make two challenge cars....then maybe at least one will finish...
4cylndrfury
7/14/10 3:38 p.m.
Apologies for my shortness, I just couldnt resist. My AE101 with the 1.6 was honestly the funnest car I ever owned (out of 4) - if only for the presence of a third pedal and a crisp clutch. A very little bit of prodding helped increase throttle response noticeably (short ram intake, fresh plugs and wires, 4-2-1 header with fiberglass tape, axleback fart cannon) and made it that much more fun. I understand advancing the timing a few degrees emphasizes this effect, the only shortcoming is you must keep 93 octane in it. With bushings, springs and some tokicos, you could have a fun car for sure.
I also wanted to get a bigger intake cam and bump overlap with an adjustable gear as I read that the 4 and 7a motors like overlap. Apparently they also benefit from lightening the valve train with aluminum retainers. Beware of crank pulleys that have aged - they separate as they are 2 pieces with a rubber busing in between to absorb vibration - the rubber shrinks as it ages and the 2 pieces slide apart and will eat belts QUICKLY - as in a day.
Supercoupe
Supercoupe Reader
7/14/10 3:47 p.m.
So, what you're saying is with a little work it could be a viable Challenge car, right?
mndsm
mndsm HalfDork
7/14/10 4:12 p.m.
Absolutely. I'd love to see it, personally. I miss my old one.
4cylndrfury
7/14/10 4:12 p.m.
Yes...but if you want to be competitive, youll almost definitely have to swap in the 4ag and boost it, remove EVERYTHING from the interior that isnt essential, and dial in the suspension meticulously. They do have macpherson strut suspension, so there is room for advancement. I can say you can get the thing to rotate pretty well without much hassle if you are smooth with steering input...found that out on accident one day . Pics are mandatory if anything comes of this build idea!
EvanB
EvanB Dork
7/14/10 4:33 p.m.
I loved my AE92 Corolla with the 4afe. Probably because it was my first car and I beat it to death. Nothing like handbrake slides around corners in a $500 car that has pieces of the body falling off every day.
Supercoupe
Supercoupe Reader
7/17/10 9:22 a.m.
picked up the Geo last night, jumped the battery and varoom, started right up. The a/c even works, another sight unseen, no inspection, online score.
Supercoupe
Supercoupe Reader
7/19/10 5:44 p.m.
besides here, what's a good reference site for the Toyota swap parts for my prizm?
Paul_VR6
Paul_VR6 Reader
7/19/10 9:15 p.m.
I have a set of oh-E36 M3 handles from a Corolla that I got for my Prism if you're interested in a big upgrade.
If mine was a 5sp I would have kept it. Fun in a very stupid way. Like the way I didn't have to ever work on it and it always ran.
93celicaGT2
7/20/10 7:36 a.m.
Supercoupe wrote: besides here, what's a good reference site for the Toyota swap parts for my prizm?
Not sure where you'd go for that car.
But someone posted up a full Silvertop swap here yesterday. You should buy it.
mndsm
mndsm HalfDork
7/20/10 8:39 a.m.
Not sure where you'd go for that car. But someone posted up a full Silvertop swap here yesterday. You should buy it.
Yes, yes you should.
Yc8hMp5VfkTrevcaZjtJtoUwb9GWXrQadDFb3Me1Aus4a8CY6VJDxj6y1SaBYL44
