mistanfo
mistanfo Dork
2/17/10 8:33 a.m.
Anything different in this job? Any special tools? I am seeing a reference on some parts sights saying "Rotors may have non-reusable spindle nut."
Is this going to be more of a pain in the rear than I really want to help a friend (and I will be laying in the snow on cardboard tonight to do it if I can).
Tom Heath
Tom Heath Marketing / Club Coordinator
2/17/10 8:37 a.m.
The spindle nut is staked on; nothing special. Wise folks would probably replace it rather than beating on it to make a new detent, but it wouldn't stop me. Pretty standard job.
Start spraying the nuts and bolts with PB blaster NOW if you want to do the job tonight.
I wish you no rust!
mistanfo
mistanfo Dork
2/17/10 8:51 a.m.
hmmm, won't see the car until tonight. Maybe I will see if I can do it when I return from VIR. Any idea on the size of spindle nut? I'm guessing bigger than my sockets go, but smaller than the few really big ones that I have bought for special projects.
Hocrest
Hocrest Reader
2/17/10 9:05 a.m.
The axle spindle nut is 32mm but you don't need to touch that to get the calipers or rotors off.
Front brakes are easy, you'll need a 19mm for the lugs, a 12mm for the bottom caliper bolt, then pull it off of the top pin. and a 17mm for the 2 bolts holding the caliper bracket to the backing plate.
Sometimes the rotor is lightly seized in place from rust, there are 2 threaded holes in the face between the lugs, use 2 bolts with the same threads as the bottom caliper bolt to push the rotor away from the hub.
klipless
klipless New Reader
2/17/10 9:05 a.m.
Why do you need to remove the spindle nut? I should probably know this since I just did the front brakes on my finance's 2000 outback a few months ago, but I don't remember removing them.
I second the call for PB blast. Watch out for seized caliper pins. I had to replace a caliper b/c of that. Turns out NAPA was the only one that could get me a part.
OVZc0IGQ19gHfaWy7HMoWqCL9DHBM8R9Ro8WhQ5EIHDnFutWHj1Jw84pxECYadlb
