PorschesOnTheCheap
PorschesOnTheCheap New Reader
3/8/09 11:54 a.m.
The wife's 2002 VW Cabrio needs new struts. I'm thinking of using this as an opportunity to upgrade her car.
The car is her daily driver, so I don't want to destroy the ride quality too much, and we can't really lower it a lot.
I remember Neuspeed sold a "SofSport" kit with Bilstein dampers and progressively-wound Eibachs that didn't lower the car much but, supposedly, firmed up the handling a bit.
Seems like a tall order - hmmmm, we want it to handle better, but we can't stiffen it up too much and we can't lower it. What to do?
gamby
gamby SuperDork
3/8/09 12:11 p.m.
Neuspeed SofSports were the same as H&R "OEM" springs (I think that's whey they're called). 3/4" drop, same spring rate as the Sports (1.5" drop).
I have them on my 99 CIvic Si (but they're dumped on the lower perches of my Koni Yellows). This is a killer combo, BTW--however, I think the ride quality (w/ the Koni Yellows) might be too stiff for a wife.
I did a KYB GR2/Neuspeed Sport combo on a former EG hatch DD and it was very compliant. I put 80k daily driver miles on that setup.
Travis_K
Travis_K Reader
3/8/09 1:05 p.m.
If I were you I would get bilstien dampers, and the stiffer gti springs (I think they are the ones used on the vr6 gti, but im not sure about that.) Most lowering springs i have had experience with were somewhat less than impressive.
Treb
Treb New Reader
3/8/09 4:10 p.m.
I have the H&R springs -- whatever they're called, the ones with about an inch of drop -- in my A3 Jetta. I like them pretty well. Definitely a good compromise spring.
KYB GR2s are a decent choice, but a little on the soft side. Then again, I have them on my wife's daily driver Fiat spider, and they aren't bad.
ValuePack
ValuePack HalfDork
3/8/09 4:54 p.m.
Travis_K wrote: If I were you I would get bilstien dampers, and the stiffer gti springs (I think they are the ones used on the vr6 gti, but im not sure about that.) Most lowering springs i have had experience with were somewhat less than impressive.
Winner. You can't go wrong with Bilstein HDs on a DDer.
MsOM34SkEsj9I5ATYlB7kK0S9rT93JJxQQI9sY2ILMYYpLFdvavq8v3ePykvymu9
