Looping back to this...and I've managed to make things worse!
Bought the HF gauges. Seemed to be starting at status quo, Compressor and condenser fan running - AC barely cooling.
I hooked up the gauges, started the car, AC on high and opened the valves to the gauges, and both gauges went to like 110+ psi. So, I shut it down right away, and re-evaluated - could not see anything wrong, but was concerned somehow the hammer store manifold was connecting hot side and low side. Also, the HF gauges were on special with 2 free self sealing cans of R134, great! - but manifold kit had no valve tap for the cans, which meant I would not be able to use the manifold to add r134a.
So, trying to press on, I connected the cheapo filler to the cold side and the manifold to the hot side. With this setup, things looked normal. Low side at about 35psi, and hot side at about 150 - classic low refrigerant symptoms. I attempt to add refrigerant, but after several minutes with two different cans of R134a, the gauges don't move. So, grabbed a scale, and the "used" new can weighs the same as a new one. Looking at the cheapo filler - it does not appear to have a pin to open the can.
Undeterred, I brought out another SUPER DUPER cheapo filler I also had laying around. Hooked it up, and crap ...with AC running, low side pegs the gauge over 100 psi - about the same as high side. Just like the first time I connected the manifold. Temp at the vents is ambient+. I also noticed a burning rubber type smell. AC belt and compressor are turning.
Thoughts?
Equal low and high side pressures - seems like dead compressor - but it wasn't dead before I started messing with it. Could it be a failed clutch?
Also, the car had been idling quite a while through all this - is it possible something overheated and changed the behavior? An AC over temp switch or overpressure would prevent the clutch from actuating, right? That does not appear to be what is happening.
Ugh... what have I done ![angry angry](https://grassrootsmotorsports.com/static/ckeditor/ckeditor/plugins/smiley/images/angry_smile.png)
