Nis14
Nis14 Reader
6/29/18 10:29 p.m.
So one of my temp sensors for my aftermarket gauge took a poo. The question I have is, could I grab a cheap eBay replacement sender? Are these sensors usually universal? Or do I have to cough up an unreasonable amount of money for a replacement from the company?
hhaase
hhaase HalfDork
6/29/18 11:38 p.m.
Semi universal at least.   If it’s the same thread and ohms it’ll usually be good.  Which one you replacing?
Nis14
Nis14 Reader
6/30/18 12:02 a.m.
The water and temp sensors wires are frayed at the sensor on my ArkDesign MFD due to vibration and heat. Same thing happened a few years ago. Just sick to dishing out 70 per sensor.
How would go about figuring out the ohms. Just stick them in water at different temps and use a multimeter?
is there an easier way? The only identifying mark on the sensor is a but 82 stamped on it
thanks!
hhaase
hhaase HalfDork
6/30/18 8:05 a.m.
No need to worry about going to that extent unless you’re trying to map the sensor curve.  Would also need a good sender to check that anyway.  If you just know what the readings are for ambient temp an at operating temp, you can figure out which you need.   Not that many different thermocouples out there.
got a manual for it? May be in the spec sheets somewhere.
APEowner
APEowner HalfDork
6/30/18 2:15 p.m.
I would expect the paperwork for the MFD to have specifications for the temperature sensor.
Nis14
Nis14 Reader
7/2/18 9:55 a.m.
The only clue that I got from the manual is that it 1/8 inch and 0-160’C range.
Which is interesting a lot of the replacement sensors Im seeing is 0-150.
hhaase
hhaase HalfDork
7/2/18 3:01 p.m.
Any chance you have a pdf of the manual?  They don’t make available unless registered owner.
Nis14
Nis14 Reader
7/2/18 7:56 p.m.
This is the only thing they mentioned in the manual. I did find this tho from Australia...
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F332326189912
Maybe? Maybe not?
Seriously wished these guys just made these sensors more sturdy.
Nis14
Nis14 Reader
7/2/18 11:15 p.m.
Got another hint.
25’C = 45kohms
30’C = 40kohms
says Ark Design
So as long as the sensor is 0-160 and has the corresponding resistance at the correct temps. Everything should be fine right?
learned something new today :)
hhaase
hhaase HalfDork
7/3/18 4:41 p.m.
Well, the 160c could be a good clue as is your few ohms readings.
Unforunately I'm just not finding any senders that meet the same ohms range.  Doesn't mean there isn't one, just that I can't find it.
GM seemed closest but didn't quite match.  The aftermarket ones I could find resistance data for didn't match up.
vGCs9en9acLtpx3cOLEIXJAU9Vu4Pb3icAm7AXAHxDMQdlYWkhwckaJ4HrJSjllv
