sporqster
sporqster Reader
7/23/12 4:26 p.m.
Does anyone know a good source for 3-piece rim components?
I have half a mind to “make” rims for my challenge car if I can get the inner and outer drawn rim components reasonably cheap and then laser (and countersink) the centers myself. This way I can get my oddball bolt pattern, width, and rims that appear to match front and back (because the bolt pattern and offset is different front to back). The idea is that I WON’T have many hundreds of dollars tied up in rims doing this. Ideally I’d like to have 17” rims. Best fat tire selection in that size without getting redonkulous large diameter. Aluminum preferred, but steel would be OK.
chandlerGTi
chandlerGTi HalfDork
7/23/12 4:31 p.m.
I've seen it done using Kinesis or HRE barrels but I'm thinking it will still run you a grand to get it done.
sporqster
sporqster Reader
7/23/12 4:55 p.m.
A friend of mine has some 2-decades old Volks that are 3-piece. Maybe I can talk him out of them.
chandlerGTi
7/23/12 5:07 p.m.
If so hit me up, I might want the centers lol
sporqster
sporqster Reader
7/24/12 7:05 a.m.
chandlerGTi wrote: If so hit me up, I might want the centers lol
He says they were stolen
MrJoshua
MrJoshua PowerDork
7/24/12 7:11 a.m.
Gainesville FL craigslist has some wide 5 barrels cheap that could be used for this concept.
z31maniac
z31maniac PowerDork
7/24/12 7:12 a.m.
sporqster wrote: The idea is that I WON’T have many hundreds of dollars tied up in rims doing this.
I'm afraid you'll likely need another idea then.
If you have to buy new, you might be able to buy just the 17" barrels/lips for the ENTIRE challenge budget.
4cylndrfury
4cylndrfury UltimaDork
7/24/12 8:14 a.m.
cut up some steelies and weld in a flange? If you have access to a cnc plasma/laser cutter, probably wouldnt be that hard to do.
sporqster
sporqster Reader
7/24/12 9:16 a.m.
4cylndrfury wrote: cut up some steelies and weld in a flange? If you have access to a cnc plasma/laser cutter, probably wouldnt be that hard to do.
Might not be a terrible idea... keeping the whole thing centered would be a concern, but maybe I can figure something out.
4cylndrfury
7/24/12 9:43 a.m.
you should be able to center the wheel in the CNC cutter, then the centering is already done (provided youre machine and code are spot on).
Or:
  • lift the car
  • mount the wheel to an undriven hub
  • place the cutter at the appropriate location for the cut on a fixed mount
  • turn on the cutter head
  • spin the wheel
Voila!! instant/poor-mans lathe. I know Iv seen a similar approach in a DIY thread from some other forum linked here, but cannot for the life of me get the google-fu flowing well enough to find it
MrJoshua
MrJoshua PowerDork
7/24/12 9:59 a.m.
Seriously, search "wide five" on the Gainesville Craigslist. All the outer sections you could ever want at good prices. It was done by a challenger in the past, it can be done again.
sporqster
sporqster Reader
7/24/12 10:36 a.m.
I assume this is what you're talking about:
http://gainesville.craigslist.org/pts/3151735411.html
I'm a long way from Gainsville, as long as seller will ship, that looks about right.
16VCorey is looking into what he can hook me up with locally.
mYZRXXV5oXfh1UdCpOGGTJpvhirJFdKCi7uqJ4bweiAcyDYYPyTkGMRpywuW7P6G
