96DXCivic
96DXCivic Reader
4/21/09 5:03 p.m.
How do aluminum rotors fare versus steel? I am a bit worried about the strength and thermal capacity compared to steel.
maroon92
maroon92 SuperDork
4/21/09 5:16 p.m.
I didn't know there was such a thing...
can't imagine aluminum holding up to the stresses...
mel_horn
mel_horn HalfDork
4/21/09 5:21 p.m.
Nor can I.
There is such a thing as composite rotors but I don't think aluminum is part of it...
AngryCorvair
AngryCorvair Dork
4/21/09 5:36 p.m.
there has only been one rotor i know of with aluminum brake plates, and that was on the rear of the Prowler. it was an aluminum metal-matrix composite, so there was lots of other stuff inside the molten aluminum when they were poured.
google "melting point of aluminum" and then google "rotor temperatures at sebring" and compare the results.
Keith
Keith SuperDork
4/21/09 5:40 p.m.
Bill Cardell at FM used to run an aluminum rotor on the back of his race bike - but that was just because he was required to have rear brakes. He never used 'em.
The classic "Minifin" for Minis is an aluminum drum, but with a steel liner.
Tim Baxter
Tim Baxter Online Editor
4/21/09 5:41 p.m.
The first time I forgot to replace brake pads--which I would surely do--would be the end of may aluminum rotors.
Too soft and easily damaged for a street car, too easy to melt for a track car.
Strizzo
Strizzo Dork
4/21/09 5:48 p.m.
they mentioned something on the top gear communinst car piece about using aluminum drums on the brakes of one of the cars, then mentioned that the soft aluminum sucked for braking
Nashco
Nashco SuperDork
4/21/09 6:03 p.m.
The only aluminum brake stuff I know of is aluminum drums, but those used an iron wear surface (as long ago as the 50s and 60s in American cars IIRC). I've never seen aluminum rotors, and can't imagine aluminum would last at all with an agressive pad choice. Even iron wears fairly quickly with aggressive pads.
I hadn't seen the Prowler rotors, I'll have to read up on that for future weird automotive trivia.
Bryce
ignorant
ignorant SuperDork
4/21/09 6:16 p.m.
OK...
We did it on the Mini Baja car. They were 7075 T6 cut like a moutain bike rotor, We CNC'd them. We then sent the parts out for a Hard Coating from Swain Tech(http://www.swaintech.com/) It was a either a carbide hardcoat or a cermaic. It was worked. We were low speed and brakes were used little. I will say the coating was tough as hell, but those rotors lasted a race. We did run Kevlar pads, due to the fact that we never put heat into the pads. IT worked.. Would never for a real car...
The calipers were anodized red( custom sliding 2 piston) and then we cut RIT Mini Baja into the showy side with a CNC mill.
2002maniac
2002maniac New Reader
4/21/09 6:51 p.m.
http://www.pitstopusa.com/SearchResult.aspx?CategoryID=3686
Roundy round cars use them sometimes. I know wilwood has a specific compound for aluminum rotors.
96DXCivic
96DXCivic Reader
4/21/09 7:01 p.m.
Ok. I didn't feel like it was a good idea but I saw it being kicked around by some FSAE guys.
InigoMontoya
InigoMontoya Reader
4/21/09 9:10 p.m.
you can do 2 piece rotors if you need big ones, AL center and then regular for the rotor piece. I know DBA makes some at a somewhat reasonable cost.
andrave
andrave New Reader
4/21/09 10:20 p.m.
Yeah aluminum "hat" as I often hear it called. many aftermarket "big brake kits" come this way. Can't think of a production vehicle that uses em though. I believe the mclaren f1 did...
Wally
Wally SuperDork
4/22/09 3:38 a.m.
2002maniac wrote: http://www.pitstopusa.com/SearchResult.aspx?CategoryID=3686 Roundy round cars use them sometimes. I know wilwood has a specific compound for aluminum rotors.
Those rotors are for the dirt sprint cars, which like iggy's mini baja racer are more for show then use. They try to shed every possible ounce from the car, including using gun drilled titanium bolts, so if the rules require brakes they run those little alum. rotors with motorcycle size calipers.
GhiaMonster
GhiaMonster New Reader
4/22/09 6:47 a.m.
We made a set for FSAE and had them coated with a high friction ceramic of some kind. Pad life: 5 laps. The rotors held up great, and stopped well but they were only on the car for one night due to the fact that we need to get atleast 20 some laps out of our brakes.
Type Q
Type Q HalfDork
4/22/09 9:40 a.m.
On the FSAE team I worked on, someone explored aluminum rotors. The conclusion was metal matrix composites like those on the Lotus Elise would work well, but not regular aluminum. This was about 1995 or so.
Keith
Keith SuperDork
4/22/09 9:54 a.m.
I don't think the Elise used them for more than a year or two, actually.
c9JUlXNcDw4dRzI5Hst5LMSs6bEVS6uJ4JzeZ0XOPMMxy2vjzpAnM9moSbWAQ0c3
