davidjs
davidjs Reader
9/10/12 10:06 a.m.
So I bought brand new tires for my wife's minivan (2010 Grand Caravan). They have less than 500 miles on them.
You can see one here: http://imgur.com/a/oodZq#0
This is the worst of the bulging, but the other side is bulged to a lesser extent.They're not overloaded, and that was at the spec tire pressure. There's also a crease right around 180* opposed to this one.
Is it just me, or is this unacceptable in a brand new tire?
GameboyRMH PowerDork
9/10/12 10:07 a.m.
It's not just you, that's horrific! Does she drive on the world's worst roads all the time?
spitfirebill
spitfirebill UltraDork
9/10/12 10:13 a.m.
Its unacceptable to me. That is exactly why I refuse to buy General tires any more. My wife had a 77 Cultass on which three of four General tires failed over about 1 year.
ransom
ransom SuperDork
9/10/12 10:14 a.m.
Seems like I see that fairly often (not necessarily on my own vehicles).
I've always wondered whether that was something to worry about...
Kenny_McCormic
Kenny_McCormic Reader
9/10/12 10:15 a.m.
Normal, I would expect nicer from General, but I have some H rated maypops on my DD that have looked that way for 20000 miles. I think it has to do with how they make them.
oldsaw
oldsaw PowerDork
9/10/12 10:21 a.m.
Those aren't bulges; they are undulations and are the result of the tire's construction.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=32
A bulge would indicate sidewall damage and the likely result of brushing against curbs or hitting a pothole and pinching the sidewall between the rim and the ground.
N Sperlo
N Sperlo PowerDork
9/10/12 10:24 a.m.
I can imagine the ride isn't as soft as it used to be...
davidjs
davidjs Reader
9/10/12 10:40 a.m.
N Sperlo wrote: I can imagine the ride isn't as soft as it used to be...
It's a 2010 Dodge Grand Caravan... ride was never exactly marvelous...
9/10/12 10:41 a.m.
Huh I'd never seen that before. I would have thought something was horribly wrong with the tire.
N Sperlo
N Sperlo PowerDork
9/10/12 10:41 a.m.
Zing!
Point taken.
sachilles
sachilles Dork
9/10/12 10:46 a.m.
I have some good year wranglers that have done the same thing.
davidjs
davidjs Reader
9/10/12 10:49 a.m.
oldsaw wrote: Those aren't bulges; they are undulations and are the result of the tire's construction. http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=32 A bulge would indicate sidewall damage and the likely result of brushing against curbs or hitting a pothole and pinching the sidewall between the rim and the ground.
Wow, thanks for the info. I've never seen tires that had this quite that badly... I didn't realize there was an innie vs outtie difference.
fasted58
fasted58 UltraDork
9/10/12 10:51 a.m.
well then, for my money I want un-undulated tires
spitfirebill
9/10/12 11:52 a.m.
I've seen innies before, but that the worst I've seen.
If you bought them from Discount Tire, take them back and throw them through the window.
bravenrace
bravenrace PowerDork
9/10/12 11:56 a.m.
I've seen that many times on new tires. Don't like it, but it seems to be pretty common.
benzbaronDaryn
benzbaronDaryn Dork
9/10/12 12:02 p.m.
One of the tires in my truck looks like that. I don't worry about it. I was wondering what that crease is, good topic.
Travis_K
Travis_K SuperDork
9/10/12 12:45 p.m.
It just means they are cheaply made tires from what I have seen. I have seen other general tires that did that, never bfg or a few others though (I think pirellis are good too).
iceracer
iceracer UltraDork
9/10/12 1:13 p.m.
Hmm, I just installed ,not myself, four General Atimax HP tires on my Fiesta.
I have only a couple hundred miles on them and I like them. They had good reviews on The Tire Rack.
bravenrace
9/10/12 1:29 p.m.
Travis_K wrote: It just means they are cheaply made tires from what I have seen. I have seen other general tires that did that, never bfg or a few others though (I think pirellis are good too).
I'm not sure about that, but years ago when I worked at a large tire dealer, I never saw tires that did that. Seems like something that has come about more recently (meaning in the past 25 years!).
oldsaw
oldsaw PowerDork
9/10/12 1:55 p.m.
I sold tires and automotive services for nine years in the 80's and early 90's. It's more common than most would think and it's been that way for a long time.
It seems more likely to occur on tires with a higher aspect ratio and softer sidewalls. Some the higher-end manufacturers do a better job but that might be one of reasons they cost more, too.
vern2point3
vern2point3 New Reader
9/10/12 2:53 p.m.
I recieved a ticket for having a tire with that much of a bulge on my Freightliner. The DOT inspector said broken belt, the Goodyear tech who replaced the tire said normal manufacturing variance.
Guess which stood up in court. I would press for a replacement, because if there's an accident you will be raked over the coals in court for letting your wife drive the car with a defective tire.
ansonivan
ansonivan Dork
9/10/12 3:22 p.m.
I have that same model of General's mounted on a 2000 honda accord, two of the tires have those same indentations in the sidewalls and the whole set is moderately out of round. I have to balance them every 5k or so and they're never perfectly balanced.
I would return them for a different brand of tires if possible.
Kenny_McCormic
9/10/12 5:29 p.m.
I have nothing but good things to say about the Altimax HP, by far the best bang:buck in terms of all season rubber. Handle great, refuse to hydroplane, good feedback, ride, etc. They even have some grip on ice. Mine were made in France, though I doubt that has anything to do with it.
chandlerGTi
chandlerGTi HalfDork
9/10/12 6:25 p.m.
vern2point3 wrote: I recieved a ticket for having a tire with that much of a bulge on my Freightliner. The DOT inspector said broken belt, the Goodyear tech who replaced the tire said normal manufacturing variance. Guess which stood up in court. I would press for a replacement, because if there's an accident you will be raked over the coals in court for letting your wife drive the car with a defective tire.
The acceptable variation for a truck under the rules is 3/8". If it is more than that it should be replaced. I had a cattle hauler come in with a 4" bubble in the side wall. Needless to say I remotely released the air before removing the wheel.
The undulation on the general tire in the OP is just a manufacturer variance. Sucks and looks crappy but it's acceptable.
32gS0AfchhTbCqevhttJxdZ07c9sTODnWyCl6X1eXeInB4spnpqQMPVvVvnCfBcJ
