Giant Purple Snorklewacker
5/6/11 11:40 a.m.
I previously just rented them with the NASA guys but BMW does not have rentals and borrowing one from someone with a broken car only works once or twice.
So... I am in need of one... first does any one have one for sale cheaply? Salanis... you are moving to Germany... jes? ;)
Second... is the signal the same for the kart models and a car models? There is a huge price discrepancy ($160 -> $399). Can I take the one off my kid's race kart and use it with BMWCCA and NASA?
dculberson
dculberson Reader
5/6/11 12:12 p.m.
The kart models should work - the difference is the speed with which you cross the timing pickup loop and how low to the ground you can mount the transponder. The kart transponders have a smaller range, but if you mount them low on the car they'll work. Make sure you don't have metal between the transponder and track surface!! I mounted mine in front of the wheel well below a frame rail using an existing unused mounting hole (was maybe the washer fluid reservoir mount) and it worked great.
Edit: I think the model number is the max speed at which it works going over the timing loop, but someone else can confirm.
motomoron
motomoron HalfDork
5/6/11 1:16 p.m.
My new to me race car had one installed already. If you buy used AMB will swap it's registration over to your account so you can see your miserable - scratch that - "heroic" results real time on mylaps/com. It's about $40 for them to do it.
Look on racingjunk, SCCA, NASA forums etc.
mhoward1
mhoward1 New Reader
5/6/11 11:12 p.m.
Yes, you can buy them used pretty cheap. I would recommend that if you buy used, buy the hard wired one. A rechargeable one may have reached the end of it's battery cycles by the time it's sold.
What part of the country are you located in? I might be able to help you out.
5/9/11 9:28 a.m.
mhoward1 wrote: What part of the country are you located in? I might be able to help you out.
Northeast PA
I have a couple weeks before I need it so I'm keeping an eye on the classifieds listed above.
OHul4N161WdsZBQOcuIhNkNd6owrJviCWLsZEI1DK0OLR3TYfs8h6fHhhb5bZSvI
