T.J.
T.J. UberDork
4/18/12 9:13 p.m.
Interesting swap mellow. I like it. Read a couple of the pages of your build thread. What are your plans for the car?
mellow65
mellow65 New Reader
4/18/12 9:56 p.m.
Stage rally.
mellow65
mellow65 New Reader
4/23/12 5:08 p.m.
mad_machine wrote: what is the chain to the alternator?
it was answered before but I wanted explain my reasoning for it better. The motor is kind of mounted on stilts. it's just the way it worked out fitting the whole thing in the car.
and to remove any kind of side to side potential movement i wanted to add something to keep it from moving.
but because this car will be used for stage rally there is always a chance of some body damage or one of the towers being pushed in. this way if i do have some tower deflection all will happen is the chain will go slack, versus if i had a more solid mount it could shove the motor..
Knurled
Knurled Dork
4/23/12 9:21 p.m.
The chain will want to twist/rock the motor mounts more, I think. It's been a while since I've had a Subaru engine out, is there enough room to stick a chunk of metal between the two mounting points?
mellow65
mellow65 New Reader
4/24/12 1:17 a.m.
Unfortunately the upper picture is about all I can do. There is an oil pan in the way. The chains arent tight by any means, so there is room to twist a little bit, it's for any kind of side to side movement. In all reality I probably don't need them, it was just something I thought about one day and added them.
BVyeO62z6nMx9l5Um15JCxIYmQb7XpIufTv4AmE3Prlmn75TjzUM3aNbYEd5YiPM
