sachilles
sachilles UltraDork
7/13/15 10:11 a.m.
What a difference 5 mph can make for cornering entry speed. Sadly a talent deficiency was the lead cause of this wreck.
Uhh whoops...video link
I was going to retire this car at the end of the season any way, as the chassis was quite rusted, and the cage was no longer conforming recent changes, but was grandfathered. It would be fixable. The short list of damage. Radiator destroyed. Oil pan dented, DOM bumper beam destroyed. Frame rails bent. Front right suspension pushed back. Engine ok. Able to coast it down the hill, and fire it up to put it on the trailer. Obviously aside from my pride, I'm ok. Happy with the performance of my hybrid pro rage neck restraint.
PeterAK
PeterAK Dork
7/13/15 10:22 a.m.
In reply to sachilles:
Ouch! Glad you are ok.
sachilles
sachilles UltraDork
7/13/15 10:30 a.m.
Pictures of the car.
 photo 20150712_161500_zpsbtalidcx.jpg  photo 20150712_161455_zpsscy3bzjr.jpg  photo 20150712_161450_zps9geaq6xd.jpg  photo 20150711_180033_zpsunrd6rtx.jpg  photo 20150711_180048_zpsytzrzvg1.jpg  photo 20150712_161446_zps71sqo54i.jpg  photo 20150712_161447_zpswlx9vuvs.jpg  photo 20150711_180019_zpsdiu93ybx.jpg  photo 20150711_175146_zpsd3dqjngq.jpg  photo 20150711_175141_zpsofgovsod.jpg
4cylndrfury
4cylndrfury MegaDork
7/13/15 10:56 a.m.
Vtec kicked in y0?
Jk, glad you're ok.
NOHOME UberDork
7/13/15 11:00 a.m.
Speedo said about 70 mph when you went off. Surprised there is ANY front end left on the car.
sachilles
sachilles UltraDork
7/13/15 11:06 a.m.
It was a bit of ditch I went into so the impact was sort of 45 degrees from level, and that DOM bar and the frame rails took it straight on. Had I gone in level, I think it would have been far worse.
dean1484
dean1484 MegaDork
7/13/15 11:11 a.m.
Just seeing trees tgat close would scare me.
jstein77
jstein77 SuperDork
7/13/15 11:19 a.m.
Also glad you're okay. Thank goodness for good safety equipment.
sachilles
sachilles UltraDork
7/13/15 11:38 a.m.
Got to say the safety equipment worked perfectly. Might adjust the neck strap a touch tighter. I'm guessing one shoulder strap was just a touch looser than the other as one shoulder was a little sore. Nice to be able to walk away and begin the self loathing without mixing in a ER visit. Not that I recommend it, but I did find it neat feeling the head and neck restraint work. Given the impact, 2 advil and a good beer was enough to make me feel OK.
rcutclif
rcutclif Dork
7/13/15 11:46 a.m.
yeah, ouch, wow. Glad you're ok!
T.J.
T.J. UltimaDork
7/13/15 11:58 a.m.
That was a pretty abrupt stop. Glad it wasn't worse and that you are fine.
pinchvalve
pinchvalve MegaDork
7/13/15 12:05 p.m.
Seemed like you should have turned left instead of going straight.
wvumtnbkr
wvumtnbkr SuperDork
7/13/15 12:27 p.m.
ufff. I feel your pain.
Good Luck with the rebuild!
HiTempguy
HiTempguy UberDork
7/13/15 12:46 p.m.
pinchvalve wrote: Seemed like you should have turned left instead of going straight.
It didn't seem like there was much braking OP?! Were you thinking the road kept going straight? Curious to what happened...
ssswitch
ssswitch Reader
7/13/15 12:49 p.m.
Wow, I'm glad you're okay. That looked brutal.
Should be a lot of good stuff to use in a rebuild with a new shell. That bumper bar probably saved the cams.
sachilles
sachilles UltraDork
7/13/15 1:45 p.m.
In reply to HiTempguy: I knew exactly where I was going.
Combo of factors. Carried 6 more mph into that corner than my previous run. There were spectators on the outside of the corner that were not suppose to be there, felt compelled to "wave them off" as I approached. That shouldn't have distracted me, but it did. Applied the brakes a split second too late. Once I got into the marbles, it was either go in straight or rotate and go in sideways and roll. I also suspect tires were cooler than optimum, but that is a guess. I knew that corner very well, so that wasn't the problem. 95% of the problem was within my helmet.
HiTempguy
HiTempguy UberDork
7/13/15 2:15 p.m.
sachilles wrote: In reply to HiTempguy: I knew exactly where I was going. Combo of factors. Carried 6 more mph into that corner than my previous run. There were spectators on the outside of the corner that were not suppose to be there, felt compelled to "wave them off" as I approached. That shouldn't have distracted me, but it did. Applied the brakes a split second too late. Once I got into the marbles, it was either go in straight or rotate and go in sideways and roll. I also suspect tires were cooler than optimum, but that is a guess. I knew that corner very well, so that wasn't the problem. 95% of the problem was within my helmet.
Fair enough!
Brett_Murphy
Brett_Murphy PowerDork
7/13/15 3:19 p.m.
Glad you're alright.
It says something that the engine was still running after that shock to the system (both you and the car).
maj75
maj75 Reader
7/14/15 1:26 p.m.
Late turn in... Usually not as bad as early turn in, unless you are REALLY late.
Glad you are OK!
21ZTiboPkDEMNFJRiZkC0NNaOj4XnsmeEwdOQeoh9qDKNzMGK5WuxZXOjkXWmPN5
