I can't figure this out, and I need to, because I need to have the car emissions tested again soon and it I think it'll fail on a technicality in its current state.
[B][U]The car[/U][/B] 1992 Mustang, 5.0 T5 A9L as it came from the factory, with a Supertune tune in it, been there for at least 6 years without trouble Pro-Flow 75mm MAF Brand new Bosch O2 sensors, bench tested beforehand, and installed before the last check ride that led to this post. Vacuum lines have all been checked, replaced as necessary. EGR is fairly new FP is 42lbs with vacuum off
[B][U]The problem[/U][/B] One day last year, with no warning and no change to anything I can think of that would cause such a thing, it started bucking violently at part throttle cruise a few minutes after startup. When this is happening, it will barely idle, smells pig rich, gets about 10mpg tops. When I say it bucks violently, it's as if somebody cuts the ignition momentarily, gives it gas, and turns the ignition back on. Violent. Still runs OK at WOT, but soft on power. In other words, it's running pig rich when this is happening. Yet the O2 sensors are still switching.
It will do this as long as the O2 sensors are hooked up, with the O2 sensors disconnected, the car runs perfectly fine. I'd be totally happy to leave it that way, but when they're disconnected, it eventually throws a CEL, and I'm afraid it won't be able to pass emissions with the CEL showing.
I'd just disconnect the CEL but the emissions tester will fail the car if the CEL doesn't illuminate when the ignition is turned on.
[B][U]Diagnostic attempts[/U][/B] I've pulled codes and all I get are a KAM problem (it's shown that ever since I had it tuned years ago), and TAB/TAD (no air pump installed). Cylinder balance test came back clean.
I installed a breakout box, and checked the following: [B]VREF[/B] is 4.98v [B]MAF[/B] checks out good, 1.05v at idle, 4.3v+ at WOT [B]TPS [/B] checks out good, 0.84 at idle, 4.6 at WOT, no dropouts when it's swept slowly [B]ECT[/B] checks out good, 0.78v at about 160 degrees [B]ACT[/B] checks out good, 1.18v at about 50 degrees [B]EVP[/B] checks out good, 0.5v at idle and WOT, 0.8v at 70mph cruise, 1.3v at 80 mph cruise, 2.8v at gentle acceleration [B]HEGOGround[/B] checks out good, 0.9 ohms with the ignition off, but resistance goes up to 33 ohms when ignition is on, and goes up as accessories are turned on. Normal? The orange ground wire is intact and securely mounted to the back of the drivers side cylinder head like it's always been. [B]O2 heater circuits[/B] both show 11.98v, so theyr'e not open or shorted [B]HEGOs[/B] both switch between 0.01 and 0.9v. I tested both of them before I installed them by heating the element until voltage got to 0.85+, then took heat away, they both dropped to 0.01v or less within 3 seconds.
In short, everything I can think of that affects the EEC feedback loop is working fine and dandy, but the car runs like E36 M3.
[B][u]So now what the hell?[/u][/B]
Again, the car runs beautifully when the O2's are disconnected, but when they're connected, it runs like total ass shortly after it's started. I'm at a complete loss, and I'm all ears.
