Keith
Keith SuperDork
2/22/11 3:53 p.m.
Look at a 1990 Miata fitment, you'll see all of the 15" sizes listed. The 15x7.5 only comes in grey, there may be a drop-down.
All of the 7-8" ones are the C1, and the 9" model is the C3M. There is a +30mm 15x7 called the C1M as well. Keep in mind that the M-suffix versions have Miata-specific hub bores, which will be a problem for your Honda.
Type Q
Type Q HalfDork
2/22/11 4:12 p.m.
The wheel offset I always used on my EG Civic was 38mm. I think up to 42mm work without issue on the EF, EG, EK, and DC platforms.
Matt B
Matt B HalfDork
2/22/11 4:43 p.m.
Keith wrote: TR Motorsports (which stands for Tire Rack, for those who haven't figured it out)
I was suspicious that they were, but didn't know for sure. Thanks for clearing that up.
Keith wrote: Keep in mind that the M-suffix versions have Miata-specific hub bores, which will be a problem for your Honda.
Although they happen to be perfect for an AW11 .
Unfortunately the hub bore is smaller than the typical Hondas, so no hub rings for you.
Birthdays
V9KRxFkbDUhxOYd6Ob7kLpuH1SgrsF1m8OOpNF4wU4DRL344uQNblRz508Y0ORIA
