For my '88 Porsche 924. Over the past few months I've been working on the body to get it (in my opinion) about 9/10, which is sufficient for my skill and planned uses for the car. Car is not going to be for shows, just want it to look decent for some road trips and occasional other driving. So basically, I'm ok with a "decent" paint job that will look good from 10 feet
I've wet-sanded the entire car at this point, Bondo's up 3 or 4 smallish dents and nicks, primed those areas and a few others to check for level-ness, and while I haven't truly "blocked" the car with the large blocks, the whole car is done down to 400 grit with a hand-block.
So at this point, thinking about actually painting it. While my rattle-can skills are pretty decent, I'm not interested in going that route and want to get it done semi-professionally (i.e. somone with the correct facility and equipment). Maaco or other budget shops is always an option, but figure if someone here is good at this stuff and local, maybe would be interested in doing it (for pay, of course!). My plan would be to have the car completely stripped and masked for priming/sealing/painting to a good extent (all the rubber removed, seals, most windows, door handles, etc etc) when it arrives. Plus would have the bumpers and pop-up light covers and mirrors off and ready to be painted "off the car" since they would be hard to paint on the car.
Other question(s):
1. Paint on the car is original, but for the touch-up spots I've basically been using whatever automotive primer I had around (Rustoleum, I think). I've heard that you shouldn't paint over this stuff for a while until it has hardened completely (like, weeks...), or can use a sealant on it.
2. The car is red (and I want it painted the same red, and will buy genuine Porsche paint for the sake of color-matching, I think). THe primer touch-up spots are mostly in gray/black primer. So some worry about the dark areas shwoing through? Or will this not be a worry if the car is fully spray-primed (via a gun, nto a rattle-can).
3. I know many of you have had "pro" paint jobs done that are perfect. But my budget is pretty small for this (i.e. Maaco-level) - so while I appreciate suggestions and advice, please don't bother suggesting thigns that are going to cost thousands and thousands of dollars. This ia a $1000 car. If it ends up looking like a $5000 Porsche, I'll be fine with that :)
pics is from a few weeks ago so more work has been done. But since threads with pics are better, this is a pic :)
