Hi
I have seen a few of these on You Tube ,
has anyone used one ?
has anyone built one ?
We are having a car show over in Europe and it would be Great to show up with one of these and see what HP the braggers really have
any ideas ?
maybe an old smog dyno ?
Beaulieu
Not sure about building one, but I occasionally see 2WD dynapacks for sale. They're pretty portable and relatively affordable (20k to 55k USD is what I've seen around here)..
20K is way out of my budget ,
I wonder if anyone has built one ?
Local portable dynoYou're not going to build one worth a shucks without some money. There is one that regularly comes to shows here, and judging by the steady line of customers, I'd say they make good money. $60 for two runs as I recall.
44Dwarf
New Reader
8/21/08 6:22 a.m.
You can make them easily enough but they will not be as good (repeatable) as a factory unit.
Water brakes dynos are some of the easiest to home brew.
You need a centrifugal (sp?) water pump and a set of bearings for the pump housing to rotate on. Bolt a torque arm off the housing and add a pressure gauge on the end of the arm, drive pump shaft with a drum the wheel sits on.
44
It's always fun to see one show up at events..
and see how many drivers find excuses Not to use it!
skierd
Dork
8/21/08 10:28 a.m.
I've used one, at Hyperfest way back in 2002 or 2003. It was fun seeing how little power my little hyundai put out.
I was thinking of using an older floor mount rolling dyno that you can get for close to scrap value,
Here in California the smog check shops use them , but are always being forced into upgrading,
The problem will be converting the computer to Horsepower , but I have been told thats its mostly software,
anyway its just an idea
Make sure the emissions dynos you're looking at can handle high horsepower and high speeds. A lot of them are glorified hamster wheels and can't handle speeds above 70mph or high torques. They're designed to simulate normal driving around town, which really doesn't require a lot of power or high speeds.
I used to have one, and built it into a trailer- My Dyno at the Mitty
![](http://www.wildhorsesracing.com/projects/DynoTrailer/20070428/tn_20070429 004_sm.jpg)
- but expect to pay at least $20k for the dyno and another $10k for the trailer...
