Caleb
New Reader
7/17/12 11:08 p.m.
So it looks like i'll be moving in a few months and won't be able to take my current project, so sadly i'm more then likely going to have to sell it pretty soon and wanted some honest appraisals and opinions on the car .
1985 Toyota Mr2 with 230k miles on the body
-20k miles on rebuild 4age
-Last owner rebuilt transmission so no gear pop out issues
-F1 stage 3 clutch
-Braided clutch line
-Runs on Megasquirt 1 V2.2
-440cc supra injectors
-Miata STO 15x6 wheels with almost new 205/45/15 dunlop direzza dz101's
-BC racing coilovers with custom spring rates F-200 R-350
-Factory Toyota strut braces off a t-top car added
-Prothane bushings
-87+ sideskirts
-89 LED wing
-MK2 rear sway bar
-New rear wheel bearings
-New ball joints all the way around
-Steering rack rebuilt
-New front inner and outer tie rods
-Upgraded to 87+brakes(1 inch bigger) all the way around with stop-tech pads and brembo rotors
-Interior has isolating Foam,Fat matted and Sound deadening mat
-Custom 2.5" exhaust
-Walbro 255 fuel pump
The bad
-Factory oil cooler is disconnected
-No AC
-Some rust in the lower quarter panels but I'll include patch panels to have these fixed
-Wind shield slightly leaks in heavy rain storms (needs to be removed and resealed)
-No Cat
-Needs paint
Raze
SuperDork
7/18/12 6:26 a.m.
I think 'where' matters...
As the previous poster said, where you/the car are located has a lot to do with how much you could expect to ask/receive for this car.
I'm originally from Pa. but now live in Fl. so if I was in Pa, the lack of A/C wouldn't bother me as much as it would in Fl. Of course, if I lived in Pa, I'd also probably be in the market for a car that is a bit more cold weather suitable (as in AWD, or at least FWD).
When I lived in Tn, you would see MR2s every once in awhile...but because they weren't a "main stream" car like a Camry, they didn't come up for sale all that often. Even here in Fl, I don't see them all that often on CL, with the 2nd gen far outnumbering the 1st gen.
In Ca, it's anyone's guess how much you could ask/get for this car. A/C isn't crucial in the bay area, but might be in L.A. or San Diego.
Off the top of my head, I'd say at least $2,500 and as high (but it might be a stretch) $3,500.
BTW, some of the "mods" you've made, like the "no cat" could impact where this car can be licensed for the road...depending on where you live. In Pa, where my father lives (VERY rural area) there are no "sniffer" tests. Where my brother lives, in Philly, there are. In Memphis, where I used to live, there was a sniffer test, but if the car is "clean" it passes...no one checks for "mods". As I understand it, Ca. checks for mods and has a statewide sniffer test.
stan
SuperDork
7/18/12 6:49 a.m.
Doesn't look like it needs paint and I don't see any rust. Based on solely what can be seen and what you've listed it looks like you should get a decent price depending on where the car is. Hard to say how much though without seeing the car in person...
Have you been around mr2oc.com much?
Why is the oil cooler not hooked up?
...and where is it?
Caleb
New Reader
7/18/12 9:01 a.m.
The car is located in VA near lynchburg which is about 2 hours west of Richmond.
The oil cooler is bypassed because the factory oil cooler sandwich plate's feed line is stripped, so it was just removed from the block. The factory oil to water oil cooler is still bolted to the firewall but it has been capped off.
Removing the cat wasn't so much a mod as on the factory exhaust i taped the exhaust with a hammer and from the header bad designated because of rust. I never replaced it because here in eastern VA there are no emissions test but i was considering dropping the 100$ and throwing in a magnaflow cat.
