stroker
stroker SuperDork
10/27/14 10:47 p.m.
I had a Check Engine light come on in my 97 Suzuki Sidekick. The PART cost to get a new EGR was more than five hundred bucks. What's up with that?
Boost_Crazy
Boost_Crazy Reader
10/27/14 10:50 p.m.
In reply to stroker:
I don't know about the price, sounds crazy high. But EGR valves don't usually go bad. The passages in the valve and in the intake manifold usually get clogged. A good cleaning usually solves the problem.
codrus
codrus Dork
10/27/14 11:02 p.m.
Why a new one rather than a junkyard one?
Desmond
Desmond Reader
10/27/14 11:10 p.m.
I was talking cars with some dude not to long ago who owned a Suzuki, and claims it was way more expensive to maintain than any Audi or BMW he had previously owned.
Kenny_McCormic
Kenny_McCormic PowerDork
10/27/14 11:59 p.m.
Probably CARB related, either directly or just plain old extortion(buy $500 part from us to pass smog, or junk the car).
codrus
codrus Dork
10/28/14 12:28 a.m.
CARB won't let you buy used cats for some reason, but AFAIK there's no prohibition against used EGR valves.
bigev007
bigev007 New Reader
10/28/14 4:44 a.m.
I tried to get a used EGR once. The yard gave up after they couldn't get it off of 4 different cars.
Cleaning mine worked. Just took it as apart as possible and sprayed it with (I believe) carb cleaner. Then worked the valve back and forth by hand until it loosened up.
44Dwarf
44Dwarf UltraDork
10/28/14 6:44 a.m.
Anyone try this stuff? PistonKleen I've seen the article about it and used to know the guy that tested it...but have not seen nor talked with him in 20+ years. Sounds like it be great for overnight soaking of EGR valves as well. My old Storm GSI would clog the passage way to the valve ever 3-4 years. pop off the valve and scrape the clot out and bolt on the valve and back to 34mpg happyness
t25torx
t25torx HalfDork
10/28/14 9:05 a.m.
The one on my Insight was something like $300, I found you could use one from a late 90's Accord and it was $70. I think the Hybrid tax got applied to the part.
Bobzilla
Bobzilla PowerDork
10/28/14 9:10 a.m.
Japanese built cars, with Japanese sourced parts are expensive? WHO KNEW!
bigdaddylee82
bigdaddylee82 Dork
10/28/14 9:13 a.m.
Block off plate, and appropriate sized resistor in place of the sensor to fool the computer? Works on P80 Volvos anyway. You can leave the dead EGR in place if you need to pass a visual inspection.
Fueled by Caffeine
Fueled by Caffeine MegaDork
10/28/14 11:52 a.m.
http://www.amazon.com/Standard-Motor-Products-EGV690-Valve/dp/B000EQA4GK/ref=au_as_r?ie=UTF8&Make=Suzuki|1&Model=Sidekick|5&Year=1997|1997&carId=3&n=15684181&newCar=1&s=automotive&vehicleType=automotive
Looks like $100 to me.
7zqaYt83BPqvyXsB2T6NRLiHZbSCZa0ImdVGLrOLHB6jNjzxEraj2EsgsxKlx2ct
