Justjim75
Justjim75 Dork
8/2/20 4:52 p.m.
BFGs are heavy too
pilotbraden
pilotbraden UltraDork
8/2/20 5:54 p.m.
In reply to Justjim75 :
Isn't eve???ry good all terrain or mud tire?
Justjim75
Justjim75 Dork
8/2/20 9:17 p.m.
In reply to pilotbraden :
Compared to other tires of the same size and category, they are, if I remember correctly neck and neck with the Nittos for the heaviest.
I'm shopping for my next set of all terrains for my 75% street driven Envoy so excessive weight can severely affect handling, ride comfort and fuel economy.
Like 41 pounds for Toyos and 49.5 for BFGs.
According to my reading 4 pounds of extra unsprung weight is 1 hp, that's the equivalent of losing 8 hp and a huge loss in fuel economy which in the middle of Peru I think the OP said is a big deal
Justjim75
Justjim75 Dork
8/2/20 9:24 p.m.
265/60r18 bfg 50.1 lbs
255/60r18 Conti 36.3
That's a huge deal to me
84FSP
84FSP UltraDork
2/19/21 11:46 a.m.
The Cooper Discovery are actually great as well.  I have like the Toyo Open Country AT and the Yokohama Geolander AT on a few vehicles and really liked them.  Snagged a full set of Yoks for the 4 runner for 660 installed off walmart.com.  They should have been 1100 but I didn't complain.
preach (fs)
preach (fs) HalfDork
2/19/21 11:56 a.m.
In reply to paul_s0 :
I have run BFGs for years. Usually get about 50k miles out of them.
Placemotorsports
Placemotorsports HalfDork
2/19/21 12:38 p.m.
Heavy yes, but they are a great tire.  I had them on my old Land Cruiser and loved them.
Vracer111
Vracer111 HalfDork
2/20/21 12:33 p.m.
irish44j (Forum Supporter) said:
paul_s0 said:
Cheers gents, I reckon the most likely option is raiding the piggy bank for the BFGs, once the supplier confirms availability (he only has 2 in the warehouse currently)
Falkens aren't available either, the complete list in 255/60 or 265/60 R18 is:
Dunlop Grandtrek (nope, failed previously)
Maxxis (nope, failed)
Nexen (no thanks)
Comforser (no thanks)
Yokohama (road tyre)
Michelin (road tyre)
BFG
Continental
Mickey Thompson (Mega $$$$)
Maybe there's a reason, but why didn't you just change to a slightly different size with more tire selection? Go slightly wider, slightly narrower, slightly taller, etc....
This... if possible go down in wheel diameter to 17" or 16"... will get much better ride, higher load capacity, and better tire durability.
I recently went from 265/70-16 Kumho Crugen HT51 (33lbs, 30.6" diameter) on stock 16x7 SV wheels to 265/75-16 Cooper Discovery AT3 4S (41lbs, 31.6" diameter) on ~4lb lighter 16X8 wheels... and ride noticeably got better - smoother & more controlled over rough surfaces and impacts even if total wheel/tire weight is ~4.5 heavier. BFG KO2 are much too heavy for me to even consider, and don't need or want Load E rated tires. The Bridgestone Dueler A/T Revo 3 would drop 2 more lbs over the Coopers... may try them next set.
dxman92
dxman92 Dork
2/20/21 12:43 p.m.
I think you made a solid choice regardless.
WnoDhunPkw6juSyDtPr8CTCvM03X2B0uM5pSpIYUe8do7vktGYfqd94ajGJ2gHnF
