DeadSkunk
DeadSkunk SuperDork
11/29/14 8:38 a.m.
Appleseed wrote:
Does anyone know which year and trim level this grille is from? I know someone who would like this for Christmas.
11/29/14 12:11 p.m.
I think its a 73. Check LMC truck for picks of the other years. Not sure if the grille varied beyond the engine size badge in the lower right corner. $135 from LMC.
Nitroracer
Nitroracer SuperDork
11/30/14 9:04 p.m.
I'm making myself an aircooled engine table, mounting the old piston and rod assemblies over the exhaust ports to support the glass. Something similar to this:
Some other ideas I've come across in searching:
License plate clock. Super easy to make with a $5 clock from walmart.
Valve cover coat rack
Ceiling Light
Photo frame from an old instrument cluster
Tailgate and trunklid tables
Cam Shaft Lamps
Opti
Opti Reader
11/30/14 9:17 p.m.
I bought an old saab turbo for 10 dollars to do dis.
noddaz
noddaz Dork
12/1/14 6:24 a.m.
Whoever made this gets extra points...
For the shape of the glass top...
turboswede
turboswede UltimaDork
12/1/14 8:32 a.m.
http://www.usclock.net/productdisplay.asp?cattype=c&ccatID=43
Grtechguy
Grtechguy UltimaDork
12/1/14 11:43 a.m.
ProDarwin wrote:
fanfoy wrote: In reply to DeadSkunk: That rolled tubing is nice. If you want there are tons of shops that can do that. But there was a sofa that someone built that had a nice mix of wood and metal. didn't require any metal bending, and worked well with the seats. They were probably from a Jag, or something english. Can't find it now, my google-fu is failing me. Edit: couldn't find it, but this looks cool too.
I have a ton of those rail fittings if anyone is interested. They are expensive to buy new.
I am... how much?
racerdave600
racerdave600 SuperDork
12/1/14 12:11 p.m.
Great thread! I've got an old Snap On bubble balancer that was in my grandfather's old Texaco station I need to do something with. You've given me ideas!
fanfoy
fanfoy Dork
2/12/15 5:06 p.m.
I'm reviving this thread because I found pictures of some really cool furniture that I saw this fall when I went to a little B&B. At first, it might look like a somewhat normal garden chair
<img src="2014-10-05 13.23.10" />
But when you look closer...
<img src="2014-10-05 13.23.18" />
Look carefully at the top.
8H0h2d1iRAoEAMLV8BSa5EYZLMh0pXGZujko4HsNYrILVrFfHUpE587dpuNXrBtn
