aussiesmg
aussiesmg MegaDork
8/25/14 6:54 p.m.
We may have a problem
Now I am in the market for a short block, hoping for some Ford guru input
I have found one I think will work but want feedback on how this looks and the parts in it, I am not an engine builder
http://www.ebay.com/itm/380643869432?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Open to leads and or suggestions
Giant Purple Snorklewacker
8/25/14 7:10 p.m.
Holy crap! Three of your pistons are installed wrong!
Curmudgeon
Curmudgeon MegaDork
8/25/14 7:14 p.m.
Naw, that's set up for the 'twist port' heads.
mndsm
mndsm MegaDork
8/25/14 7:15 p.m.
You mean green slime in the the cylinder bores is bad? I've been doing it wrong!
dean1484
dean1484 UltimaDork
8/25/14 7:21 p.m.
Photos of the carnage once you remove the pan are going to be intresting.
On a side note your block may be ok jusy depends on what hsppened down under.
aussiesmg
aussiesmg MegaDork
8/25/14 7:28 p.m.
We had the pan off and the bottom seems fine, rod probably stretched and then let go on a cold start
Good excuse to get a 331 anyway
Mazdax605
Mazdax605 SuperDork
8/25/14 7:35 p.m.
Is this on the Mustang you got up this way, Steve?
SyntheticBlinkerFluid
8/25/14 7:39 p.m.
Aww damn, I thought this was about me.
mndsm
mndsm MegaDork
8/25/14 7:44 p.m.
Here's some dope compomotives, just for you.
8/25/14 8:00 p.m.
Nice!
aussiesmg
aussiesmg MegaDork
8/25/14 8:06 p.m.
Mazdax605 wrote: Is this on the Mustang you got up this way, Steve?
No wounded the RX5.0, chasing an engine in your area though, open to another check and view for me
Raynham, MA
JohnRW1621
JohnRW1621 UltimaDork
8/25/14 8:31 p.m.
Sorry for your loss. You and your family are in my prayers.
http://fortwayne.craigslist.org/pts/4627555223.html
http://limaohio.craigslist.org/pts/4627690834.html
http://limaohio.craigslist.org/pts/4635309787.html
http://fortwayne.craigslist.org/pts/4597660644.html
aussiesmg
aussiesmg MegaDork
8/25/14 9:15 p.m.
You should know me better than than John, nothing stock is going back in there
aussiesmg
aussiesmg MegaDork
8/25/14 9:22 p.m.
A couple of hours on Facebook and I found a great candidate
High compression 306, Ross pistons, good block for someone who's building a nitrous or n/a car, forged rods and crank, a girdle support
aussiesmg
aussiesmg MegaDork
8/25/14 11:28 p.m.
Side B is no better
and from there it gets worse
Shrapnel
It fits in here somewhere
Maybe not
novaderrik
novaderrik PowerDork
8/26/14 2:10 a.m.
let me guess... it was just idling and you totally weren't beating on it at all when that happened..
aussiesmg
aussiesmg MegaDork
8/26/14 2:48 a.m.
novaderrik wrote: let me guess... it was just idling and you totally weren't beating on it at all when that happened..
It was, we just went through the fuel system, pulled the pan to check the bottom end and put it back together, started it and it made a bunch of loud noises, turned it off and it wouldn't turn over again.
We actually went over the bottom end when the pan was off and checked end play with gauges, nothing obvious was out of place.
Mazdax605
Mazdax605 SuperDork
8/26/14 12:21 p.m.
No wounded the RX5.0, chasing an engine in your area though, open to another check and view for me Raynham, MA
Of course I would love to help. My brother-in-law is a really Mustang guy so I will drag him along. Raynham is just around the corner. Let me know the details.
Chris
Gearheadotaku
Gearheadotaku PowerDork
8/26/14 12:31 p.m.
dean1484 wrote: Photos of the carnage once you remove the pan are going to be intresting. On a side note your block may be ok just depends on what happened down under
I see what you did there...
At least you've got other stuff to drive in the meantime.
Kenny_McCormic
Kenny_McCormic PowerDork
8/26/14 1:30 p.m.
It was, we just went through the fuel system, pulled the pan to check the bottom end and put it back together, started it and it made a bunch of loud noises, turned it off and it wouldn't turn over again. We actually went over the bottom end when the pan was off and checked end play with gauges, nothing obvious was out of place.
Did you money shift it right before that or something? Really weird that 2 rods let go at once, at startup.
AngryCorvair
AngryCorvair UltimaDork
8/26/14 4:10 p.m.
Kenny_McCormic wrote:
It was, we just went through the fuel system, pulled the pan to check the bottom end and put it back together, started it and it made a bunch of loud noises, turned it off and it wouldn't turn over again. We actually went over the bottom end when the pan was off and checked end play with gauges, nothing obvious was out of place so we buttoned it up without torquing the rod bolts.
Kenny_McCormic
8/26/14 5:12 p.m.
In reply to AngryCorvair:
The rod bolts are almost entirely a tension load, so forgetting to torque them would not cause an immediate failure at idle like this.
EDIT: GOT IT, removed the rod caps, plastigauged, then a faulty torque wrench led to an over tightening of the rod bolts putting them well into yield seriously weakening them.
beans
beans Dork
8/26/14 9:42 p.m.
Bring me beer and help me yank the engine/trans out of the roommate's mustang and I'll take the $3000 you wanna give me!
vjRRjcGSowGi5nyzJIkFtTGelXScazGBm707kpFQ1NgwJSPtWTX5p32ofT3de4GO
